Hardware In Win 301 Review
Discussion in 'Article Discussion' started by Dogbert666, 11 May 2017.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. Vault-Tec
    30 Aug 2015
    Bang tidy. Fans are no big loss, as they would usually get replaced any way.
  3. davido_labido
    davido_labido Your Alphacool Contact.
    11 Oct 2013
    Really like this. Might have to cut it up a bit :D
  4. Guest-16
    Guest-16 Guest
    There's an even better one coming up at Computex (imo)
    Ohivesaidtoomuch
  5. Anfield
    Anfield Multimodder
    15 Jan 2010
    Nah, we are so spoilt for choice with cases we would forget in 5 minutes flat if you revealed every upcoming case for the next five years in detail.
  6. Guest-56605
    Guest-56605 Guest
    Definitely liking the look of this :thumb:
  7. Combatus
    16 Feb 2009
    In Win has SFX PSUs now so I hope they have plans to do a new mini-ITX case that ditches that huge ATX chamber up top - even the 301 could be easily modified for this and made smaller. I know ITX is still niche, but since when did In Win care about that? The 901 was a gorgeous little case but it was all wrong inside - next to no all-in-one liquid cooler or water-cooling support and a huge amount of wasted space. It was too expensive given these shortcomings - if you're spending upwards of £100 on an ITX case, you're almost certainly going to want to water-cool it.
  8. davido_labido
    11 Oct 2013
    This. I already know what I am going to be doing with this when I get it... Chopping out the PSU and banging an SFX in it, creating a little more rad space, dropping to an ITX mobo to fit in everything I want.... nom.
  9. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    mine arrives on sat, in white.... didnt know about fans not being included, thank you matt
  10. specialworks
    specialworks Design matters
    11 Jul 2007
    Thanks bit-tech for being prompt.
    my plan: https://pcpartpicker.com/user/Sp4rky/saved/#view=3BsgsY
    yup, going SFX in the top chamber... and planning a 2 rad CPU GPU loop...
    The 3 o 1 is in stock here in Hong Kong, just waiting for those pesky mATX AM4 X370 boards - seems a lot of attention bringing out even more Z270 boards, which seems unnecessary! Maybe someone in the know can share the love some on Ryzen board plans for the compact crowd, with Computex round the corner...
    Qs: - can bit-tech tell us if those bottom intakes would squeeze in 140mm fans (with 120mm fan hole mounts like the Noctua NF-P14R-REDUX-1500-PWM)?
    cheers, Sparky
  11. Dogbert666
    17 Jan 2010
    If I have time, I will try to find out for you on Monday. No promises though!
  12. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    Likewise, can a 240 rad fit on the bottom? Especially in conjunction with a 240 rad at the front.
    Thanks.
  13. SomeGuySomeDay
    SomeGuySomeDay What's a Dremel?
    19 Dec 2007
    The case is designed for intake fans in bottom, and exhaust fans in front, pushing air out the side through the hex pattern. You can see an illustration on InWins product site. Can you test with that configuration? This review really tells us nothing about the case's cooling capacity.
Tags: Add Tags
