Hardware In Win 904 Review
Discussion in 'Article Discussion' started by Meanmotion, 23 Jan 2014.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. Shirty
    18 Apr 1982
    I've decided that I think this case is minging. Looks beautifully constructed, but I don't like the looks personally. I still have a strange urge to own one though :confused:
  3. kent thomsen
    kent thomsen What's a Dremel?
    9 Jul 2011
    Great review, and a great looking case. I can only agree, that it´s bold and brave.
    Since you can´t use massive high-end aircooled heatsinks, one might suspect it was meant for quiet operation, which probably also will appeal to the potential costumers for this enclosure.
    It would be great, if you could make just a brief comment on noise.
    I´m happy with my P182, but this one is - in my opinion - a real looker, and if a little tinkering and an extra fan or two could make it real cool and quiet too, it certainly could be a good replacement.
    I don´t think you have to worry too much about the glass, I used to work with hardened in a factory once, and it´s trmendously much stronger, than one expects.
  4. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    It's very 90s Bang and Olufsen, isn't it?
    Absolutely not to my taste at all, but I must say fair play for the balls to do something completely different.
  5. kent thomsen
    9 Jul 2011
    Haha, I guess you nailed it! (And I am from Denmark and my stereo is a 90´es B&O... :))
  6. Combatus
    16 Feb 2009
    There is no noise - no fans included :D or did you mean did it seem to allow more/less sound to escape than a standard case, something like that? I have to admit getting out of the box was very awkward and at one point it slipped and there was a massive clunk from the glass. Half-expected to be hoovering up shards for the rest of the afternoon but not even a scratch :D
  7. AlienwareAndy
    7 Dec 2009
    You lucky person :D
    Around that time I had a Denon mini system (the ones that were anodized in gold and had motorised tape units). I'd give anything to get it back :(
  8. kent thomsen
    9 Jul 2011
    Oh, no, of course, you´re right :) But it was tested with three fans as well, just wondering if it was very noisy or perhaps the opposite or more average. But maybe the taping up the sidepanel dosn´t really give a true picture anyway. Just seems sounddampening foam is a little against the concept on this case...
    Yeah, the glass really is tough. A one meter long, half a meter wide and 6 mm thick piece with a couple of bricks under the far ends, could carry me and my workmate and our 175 kg without beeing close to breaking. The only weak spots are the edges, a hard hit perpendicular to the edge will chip it or ultimately cause it to break.
  9. law99
    law99 Custom User Title
    24 Sep 2009
    First sentence might need an extra e in it somewhere... :D
    Edit: just read review. I really like the look. There appears to be a smaller one also. In Win 901.
  10. Waynio
    Waynio Relaxing
    20 Aug 2009
    I like imperfect but nice looking cases, they are perfect case modding foundation material with good reason to mod it, if I wasn't bothered about completing my time sink of a project I'd have ordered one already cooking up some nice enhancements, it's even tempting to buy one to mod at a later date.
  11. David
    7 Apr 2009
    This
  12. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    So is the 901 review on it's way by any chance?
  13. Jedibeeftrix
    Jedibeeftrix What's a Dremel?
    20 Jan 2011
    one question:
    when does the mITX 901 go on sale in the UK?
  14. law99
    24 Sep 2009
    Yes... Tell us about the 901. It seems like the perfect candidate for a new build.
Tags: Add Tags
