Hardware In-Win G7 Review
Discussion in 'Article Discussion' started by Meanmotion, 10 Jul 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. Xir
    Xir Modder
    26 Apr 2006
    I don't understand case designers.
    It comes with dust-filters, but at the same time half the side panel is open without a filter, letting in dust and letting noise out.
  3. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Yeah, it's crazy how often side panel fan mounts in particular are left without dust filters or even blanking plates.
  4. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Any case with a side window/fan is an immediate no for me personally.
  5. David
    7 Apr 2009
    It's an In-WIn Mana 137 with a face lift and a 30% price hike.
    +1 on the gaping side panel with no blanking plate or filters.
    YEHBABY likes this.
  6. Dogbert666
    17 Jan 2010
    As a reviewer I have to acknowledge the benefits side fan mounts can bring to GPU cooling, for example, but personally I'd have to agree as well, although I'm not necessarily put off by windows. I'd rather cool my graphics card with slow spinning front and bottom fans, which target most cards' intake areas better anyway.
  7. Meanmotion
    16 Nov 2003
    Just to emphasise that point: http://www.bit-tech.net/hardware/2012/02/10/the-big-cooling-investigation/1
    Our tests comprehensively proved that the side fan was the single most effective for fan configurations of four or less.
  8. Corky42
    30 Oct 2012
    Yea i agree for a out of the box setup a side fan would be best, although sometimes with a little modding you can get better cooling, it all depends on the case and what your willing to change,
  9. LordPyrinc
    LordPyrinc Legomaniac
    7 Mar 2008
    From personal experience, side panel fans definitely make a measurable difference in GPU cooling especially in an SLI configuration. While plexi-glass side panels show off the guts nicely, I prefer being able to mount a side panel fan.
    A buddy of mine is going to replace the stock coolers on my old 550s soon and I'm curious to see what the temps are like on those once he's got it up and running. Seems like I've gone as far as I can with fan cooling without replacing the stock coolers on my 660s. I went from an Antec Three Hundred to a HAF 922 and it definitely made a big difference with the larger fans. I've got two 200mm fans pushing and a 120mm and a 200mm pulling air out right now.
  10. Xir
    Xir Modder
    26 Apr 2006
    Correct as that may be, an unfiltered side fan negates all other filters.
  11. LightningPete
    LightningPete Diagnosis: ARMAII-Holic
    2 Jul 2009
    I have 4 side fans, do I win a medal?
    Coolermaster Stacker Cheesecake ;)
Tags: Add Tags
