News In-Win shows off sound-proof space case
Discussion in 'Article Discussion' started by Sifter3000, 11 Jun 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. Apocalypso
    Apocalypso Fully armed and operational.
    15 Sep 2007
    As long as it keeps my beer cold.
  3. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    I expect some modders to replace the useless back with a Rad. ;)
  4. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    I like a big booty, but not a fat PC case!
  5. Bakes
    Bakes What's a Dremel?
    4 Jun 2010
    The back is probably not useless, that sort of foam does absorb noise very well. Also, putting a rad with noise-making fans on the back would defeat the purpose of the case.
    What I'd say is that silencing usually comes at the price of cooling ability, so I wouldn't want to be putting a high-end rig in this, where the size would call for it.
  6. Jipa
    5 Feb 2004
    Wouldn't mind giving it a try.
  7. kHAn_au
    kHAn_au What's a Dremel?
    12 Dec 2005
    frankley i like it I'd love to have one.
  8. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    No inside shots? :(
  9. mrbens
    mrbens What's a Dremel?
    15 Aug 2009
    If you're liquid cooling your CPU + GPU you won't need a silencing case anyway unless you have 5 hard drives constantly wurring away!
    BTW rad fans can be fitted to a fan controller and turned down so you can't hear them and they still cool way better than a noisey HSF at top speed.
    Liquid cooling my PC is the best thing I've ever done to it!
    Shame my new flatmate has moved his noisey PC in tho :(
    I can't hear the TV properly when he's gaming!
  10. Bakes
    4 Jun 2010
    This is more of a concept than anything else, remember. It's designed for total silence, if you want an example of the potential uses of this, it could be useful in a home recording studio, where ultra-sensitive microphones can pick up noise from even the quietest computers.
  11. Guest-2867
    Guest-2867 Guest
    I'd buy it, looks like a cool retro data center/scientific type casing. Any chance of a review?
  12. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    All case aren't mean to gaming. With the right component if the case fulfill it's objective you might be able to have one totally silent pc on aircooling.
  13. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    I would be open to giving it a shot if the temps stay good.
  14. rickysio
    6 Jun 2009
    Those situations call for passive cooled systems, ergo, this case is useless for that.
  15. minus0ne
    minus0ne What's a Dremel?
    10 Jul 2009
    If you want a silent case then high-end air-cooling is the way to go, even the best and more expensive pumps can't beat silent fans these days.
  16. Bakes
    4 Jun 2010
    You'd be surprised at how many silent cases there are on the market. They're definitely in single digits. Even if you cool most of the stuff passively, you've still got a power supply, a hard drive and potentially a dvd drive making a signficant amount of noise.
    There are so few passive cases on the market that the suggestion you make is a
    Disagree. A CPU covered by one fan will always be noisier than a CPU covered by three fans, ie with a triple radiator.
    Also, as with the point above, you've got the hard drives, the accessories etc all making noise. This has it's niche, and that niche is where silent means silent, where 'very quiet' is not quiet enough.
  17. D-Cyph3r
    D-Cyph3r Gay for Yunosuke
    31 Aug 2008
    But will it absorb the sound of people snoring when you try to explain the sound insulation properties of it?
Tags: Add Tags
