Electronics Increase voltage
Discussion in 'Modding' started by WarpiG, 20 Apr 2007.
  1. WarpiG
    WarpiG What's a Dremel?
    23 Apr 2004
    Is there a way to increase voltage from 4.8 volts to around 7 volts?
    I race electric RC cars and I thinking is there a way to increase the voltage from the battery pack (4.8v)to the electonic speed controller with out adding another cell to the battery pack. Some kind of DC to DC converter. It would have to be small and light. Handle about 7 to 9 amps.
  2. ChromeX
    ChromeX Minimodder
    12 Aug 2004
    step up transformer? That would be my first guess, shouldnt need too many windings to take 4.8v to 7 so it shouldnt be heavy and it should handle 7 amps, though that does seem an awful lot for an rc car are you sure about the current?
  3. veryevil
    veryevil Minimodder
    14 Aug 2005
    You would also have to convert the DC to AC to use a transformer. There doesnt seem to be any DC/DC converters that will handle that sort of current the highest rated ones ive seen are 10W.
  4. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    It may be possible to attach a transistor(darlington array) to supplement the output of the converter IC. The transistor, if selected correctly and with the proper heatsinking, will handle the extra current load through itself.
    Your efficiency and switching frequency may suffer but playing around with the values will yield the best results.
  5. WarpiG
    23 Apr 2004
    Xiachunyi, I'm a noob at this stuff. Where would I find the parts/schematics for something like that?
  6. const_
    const_ What's a Dremel?
    15 Nov 2005
    hey, i think you could use 3 diodes normal ones and connect it to the ground of the speed control and then to ground something like this
    (ground speed control)----->|-->|-->|---| where(-->|--) is a diode just like this link
    http://www.semis.demon.co.uk/Pics/ppwincct.bmp
    he used two diodes to bring the voltage to 13.4 down from 12 out of the voltage regulator (12 + 2*(0.7)) ~~ 13.4v
    yours (4.8 + 3*(0.7)) = 6.9 ~ 7v
  7. Xiachunyi
    3 Nov 2003
    This (pdf) may be a likely candidate for what you want.
    Scroll down to page 11 and you will find some information on using an external transistor to boost the available current. Page 14 contains the design equations you will need to use to get approximate values for your needed components.
    Since I assume you do not wish to mess around with SMT, here is a link to the DIP form of the chip: MC34163PG Make sure to adjust the size of the inductor and diode accordingly since you will be pulling all of your needed current through those components.
  8. WarpiG
    23 Apr 2004
    Thanks for the replys, but I think this one is over my head. I looked at the pdf and I don't understand enough of it.
    Thanks again
  9. Xiachunyi
    3 Nov 2003
    Sorry to hear that. One thing I must ask, are you sure about the amount of current you need from the battery pack is that much? How big is your battery?
  10. WarpiG
    23 Apr 2004
    The battery pack contain four cells. Each cell is 1.23 volts/4200 mah. These batteries have a discharge rate of 30 amps. The motor pulls about 8 amps from a dead stop. When the motor gets going I'm sure the amps drop a little.
  11. Xiachunyi
    3 Nov 2003
    Hmm, I tried searching around for a commercial solution but it seems that all the converters that can fill that kind specification require a higher input voltage. Not to mention they are expensive and a little hard to acquire.
  12. tech3312
    tech3312 Where's my dremel o.0
    1 Apr 2007
    I can increase it to 5V using a boost converter if 5 V is ok
  13. Snipes0990
    Snipes0990 What's a Dremel?
    4 Oct 2005
  14. blaffer4x4
    blaffer4x4 What's a Dremel?
    13 Oct 2004
    I think your drain will be increased greatly. Once your engine is up to speed it will be acceptable, but from dead stop, i think your batteries will drain much much quicker in comparison. What type do you race?
