Windows Increased Windows Speed
Discussion in 'Software' started by xckid082488, 18 Sep 2004.
  1. xckid082488
    xckid082488 Banned
    18 Sep 2004
    Its an incredible tool for avid gamers that optimizes Windows XP for gaming.
    See it here, http://www.techwarelabs.com/downloa...ion=file&id=172
    Well, it sounded really cool so I set a system recovery point just incase. So I downloaded it, unzipped it, and ran it. It restarted in half the time it usually does and farcry ran much smoother than it usually does. Everything in windows loaded/ran faster than ever then I discovered something. I couldn't connect to the internet through my wireless router. So I was forced to restore to the point I had just made. I'm so pissed, windows was running so fast. I highly recommend you try this if you dont have a wireless router, and if your really tech savey try to fix it if you use a wireless router and if you do get back to me
  2. Firehed
    15 Feb 2004
    I got that as a broken link.
  3. kobaj
    kobaj Banned
    4 Jul 2004
    ditto
  4. quack
    quack Minimodder
    6 Mar 2002
  5. a9on87
    a9on87 ...
    2 Nov 2003
    me reckons that xckid082488 is just pimping his companies product - he has 2 posts both pimping the same thing.
  6. xckid082488
    xckid082488 Banned
    18 Sep 2004
    first of all, thats not my product. second of all, its not even my website :wallbash:
  7. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    xckid082488 New Yorker Huh? Cool man. what part of ny are you from?
  8. a9on87
    a9on87 ...
    2 Nov 2003
    fair enough, just it's been quite common here lately that people sign up to just pimp stuff. Sorry for wrongly accusing you!
  9. Guest-16
    Guest-16 Guest
    xckid, any chance you could cut down that 10 line sig into something like 4 or 5? Ta :)
  10. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    I tried this, it did seem to make doom3 a little more responsive (seeing as im running at stock atm), havent found any issues yet :thumb:
  11. TMM
    TMM Modder
    12 Jan 2004
    it just disabled some services... one of which was critical for windows to know which user belongs to which process ;)
  12. jezmck
    jezmck Minimodder
    25 Sep 2003
    so is this thing worth it?
  13. Xen0phobiak
    8 Aug 2002
    Seems worth trying imo, just reenable the security accounts manager service.
  14. quack
    quack Minimodder
    6 Mar 2002
    Simply re-enable Wireless Zero Configuration, changing it from Disabled to Automatic.
    This tool is handy, but a little over-zealous at which services are disabled.
    It's probably a good thing to run it, then double check in Services to make sure that nothing was Disabled that you REALLY do need. :thumb:
    Or... disable stuff by hand. :)
  15. kobaj
    kobaj Banned
    4 Jul 2004
    It seems faster and so far no problems,besides loading faster it took a while to find my router and alow me to get on the net.I also see that it also gets rid of little animations like the task bar if you hit the extend arrow it instantly goes to it,it used to slowly come out and.Also when I see how it maneges my tasks it is doing ok I think I will be keeping this little download
  16. kobaj
    kobaj Banned
    4 Jul 2004
    Sorry for the double post.It's a disaster I go to "control panel" and everything is messed up I know I dont ever go there but I liked the old way how do I get rid of this thing. Its like this with all the windows.
  17. kobaj
    kobaj Banned
    4 Jul 2004
    Sorry for the triple post.Ok I just uninstalled it and everything is back to normal but I look at my prosseces list and I didnt know all of them used that much prossecer stuff.I think I will only use it when I'm seriusly gaming but not now.
  18. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    Please, for the love of all that's holy, use it.
  19. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    Please use edit!!! :wallbash:
    Anyway i just turned the animations back on after running the program.
  20. quack
    quack Minimodder
    6 Mar 2002
    Re-enable Terminal Services and Security Accounts Manager.
