Modding Industrial PC
Discussion in 'Modding' started by HollowFrank, 21 May 2005.
  1. HollowFrank
    HollowFrank New Member
    21 May 2005
    I'm researching and looking into parts and components for an industrial styled PC with a few notable features, I would like to know if anyone knows of a supplier that stocks switches like these but with a push switch instead of a toggle, cheers.
  2. ElThomsono
    ElThomsono Well-Known Member
    18 Mar 2005
    I've seen a lot of those at various sites, but the were all toggles. That housing's just a standard cover though, I suggest you buy it, and install a push switch yourself. I you want to keep the looks though, you can buy toggle switches that automatically spring back when you let go, so it'd look the same, but act like a push switch.
  3. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    ooo i love that switch, i want to put my vertical fan in with a switch, and thats perfect, bit different but cool as well.
  4. HollowFrank
    21 May 2005
    I know i can easily replace the toggles with pushes, was just trying to save myself a bit of hassle. I need to measure up some sizes because I know you can get pulsating lit red push switches, if they fit I may fit them with these covers.
    I do like these switches, Maplins call them "Missile style" i thought they'd be perfect for something that's going to look like a functional piece of machinery.
  5. ehrnam45
    ehrnam45 New Member
    5 Jul 2004
    another idea would be to get some 22mm square illuminated pushbuttons with clear flip-up style protectors. Those always seem to make it onto control panels for nuclear missiles and space lasers. You could also get a big red EMERGENCY STOP type button to do something silly, or put rubber environmental seals/dust boots on your pushbuttons/toggles.
  6. bobmister
    bobmister New Member
    17 Mar 2005
    how 'bout this for an industrial PC...
  7. Isuo
    Isuo New Member
    13 Oct 2004
    offtopic: Does that fly? :D
  8. Ghlargh
    Ghlargh New Member
    16 Nov 2003
    I use industrial backlit pushbuttons for power and reset with power-LED and HDD-LED as the lights. I had to replace the lamp holder with a LED thou, and i tell you, it's not easy soldering inside one of those switch bases :D
  9. HollowFrank
    21 May 2005
    bobmister: i want mine to look more like machinery than electronics, something that works with clanking parts and so on, and that is a hell of a meaty fan
    ehrnam45: those kinda buttons tend to be for the big final boom, hmm...maybe i'll mod a set of peripherals to go with it with that as a reset switch on the keyboard, that shouldn't be too hard to set up.
  10. nick01
    nick01 New Member
    6 Nov 2004
  11. HollowFrank
    21 May 2005
    Cheers, you're right, they are a little on the expensive side, but at least i know they're available. Cheers for the info.
