Case Mod - In Progress Inet 001 - Codename Mono - Final pictures!
Discussion in 'Project Logs' started by Laine, 31 Mar 2012.
  1. Laine
    Laine This and that
    14 Dec 2010
    This project is made on behalf of
    *Awards are valid for Sweden only.
    I give the word over to the people behind Inet;
    "We here at Inet felt that we needed somehing special and unique to mark the start of something new, the acquisition of Indomo. A new era for computer modification and watercooling in Sweden.
    We are proud to present our collaboration with Laine. For a couple of weeks you will get to follow as his creation comes to life. We gave Laine free hands to create and choose both what the computer should look like and what it should contain, both on hardware and cooling.
    Here is part one av Mono - something beyond the ordinary."
    Pre-release;
    A hastely thrown together 'proof of concept' of watercooling in a Lian Li PC-Q11B. I wanted to know that it was possible to get your basic setup into the case before promising anything about something groundbreaking.
    The things again hastely mounted in the case to get an estimate of what will fit, this time the real deal, a PC-Q11W.
    Early planning and placement of both the PSU and the rear radiator.
    The PC-Q11W in relation to a Streacom/Wesena F1C. The computer on top is called Nano and a Swedish gallery for it can be found [HERE].
    Partslist;
    Hardware:
    CPU: Intel i7 2600K
    GPU: EVGA GeForce GTX 670 2048MB
    MB: ZOTAC Z68-ITX WiFi
    RAM: Corsair 8GB (2x4096MB) CL9 1600Mhz VENGEANCE LP White
    PSU: Silverstone ST45SF 450W
    SSD: Corsair SSD Force GT 120GB x2
    CSE: Lian Li PC-Q11W
    Cooling:
    PMP: EK DCP 2.2
    RAD: Black ICE SR1 120mm
    RAD: Black ICE SR1 140mm
    RES: EK Multioption 100mm
    GPU: EK-FC670 GTX
    CPU: EK Supreme HF
    And copious amounts of mixed Bitspower fittings (quite a bit over 50 I think).
  2. Laine
    Laine This and that
    14 Dec 2010
    Part I
    And I got the green light for release, here we go.
    The build, already from the start, had some clear goals. A small footprint, light construction and of course, to be uncompromised.
    These goals had to be reached without sacrificing performance.
    Somewhat stripped front, but this is where I started the build.
    Test fitting of the parts. The rear houses both a custom made adapter for SFX-PSUs and a somewhat trimmed down version of a Bitspower Mesh Radguard 120mm.
    And for you who are curious regarding the studio and photos, here is a peak at the current one.
    And the radiators for this build. I chose these because of the low FPI, giving the possibility to run the build as silently as possible.
    The radiators are paired up with one Scythe Slip Stream 1200rpm 120mm each. From the left; Modded with a 140mm frame - stock - modded by removing the frame almost completely.
    Not the best caption ever, but here you can see the fans lowered into the radiators, making them almost invisible.
    And for storage, these beauties! A pair of Corsair Force GT 120GB.
    Part II of this build will most probably be presented on Monday the upcomming week, with part III on Wednesday and part IIII on Friday.
  3. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    Interesting.
  4. Laine
    Laine This and that
    14 Dec 2010
    Thank you for your interest, it's a bit hard getting used to a new forum like this, especially since I haven't got the chance to prove my self on here yet. But all in due time, I hope.
    Also I can't release too much information, or pictures right now since the 'big boys' at Inet have to keep up with me on their Facebook page and what not. But yeah, if you like the build or do in the future, feel free to drop a line to Inet to show that the "venture" is worth it, and that there is an interest for these kind of things. :)
    In the mean time, I have some links to my older logs (in Swedish but with lots of pictures) in my signature below if it would be of interest for some.
    Also found this here on Bit-Tech; http://forums.bit-tech.net/showthread.php?t=199574
  5. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Nice to see this little water-cooled build. :D
    Beautiful modding Laine.
  6. spigs_rex
    spigs_rex What's a Dremel?
    1 Oct 2010
    yep, another itx watercooled case to watch :D
  7. Furball Zen
    25 Jan 2012
    I was gonna ask if you were Laine from XS and considering your sig, that would be you. Dont be offended when i say your photog skills are better than your modding lol.
  8. johnaton
    johnaton What's a Dremel?
    14 Dec 2010
    wow very nice, i am also modding the same case as u
  9. Laine
    Laine This and that
    14 Dec 2010
    Thank you, Craig my friend! :)
    Yay! Haha, another watercooled build to visit frequently, I hope? ;)
    Haha, yeah thats me! We'll have to put a stop to that being true then. ;)
    It's a small world. :thumb: These are great little cases though!
    Part II
    The radguard got a nice glossy white finish to match the rest of the exterior.
    And the insides were coated in a satin black, along with the radiator now being a flat white.
    Test mounting of the motherboard, after painting the cooler the same flat white as the radiator.
    Those Vengeance-sticks are beautiful!
    Here's a better view of the WLAN adapter. The bracket holding the antennas and the one holding the adapter itself were both finished of in black, same goes with the adapter. The cables got rerouted through the cooler.
    Some more planning of the loop.
    EK FC-GTX580DCII that I modded on to a KFA2 GTX570. Still some left to do until a perfect fit.
    Next update, this Wednesday!
  10. Mr3D
    Mr3D What's a Dremel?
    23 Dec 2011
    Whoa! Stunning build, keep up the good work mate! :D
  11. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    Very cool, I'm just curious as to how those fans perform, they look VERY small.
  12. Laine
    Laine This and that
    14 Dec 2010
    Thanks, Daniel!
    My requirements aren't very hard, just keep it somewhat cool but no records. Silence over temperatures in this case. And looks over silence. :thumb:
    Part III:I
    Some time ago I painted the ports. Do NOT try this at home if you're not 100% sure that you are capable of doing it correctly. It will most likely kill your motherboard. I put down a hard 4 hours of prepwork and masking, and another 4 hours n the paintbooth. Do not spend any less and expect a good result.
    Only the Sata-ports stand out, but in a quite charming way.
    Stay tuned for part III:II, most likely on friday.
  13. Pranja
    Pranja Blackwolf
    18 Dec 2011
    This is really nice and neat. Good job!
    Can't wait to see it finished.
  14. Parge
    16 Jul 2010
    Loving the look of this! Mini builds rock! Subbed!
  15. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    good to see you here too laine :) welcome to bit-tech forums! :)
    Looking forward to a rather "artistic" buildlog :)
  16. y0gi
    y0gi What's a Dremel?
    23 Nov 2010
    Nicely done as always Laine. Keep it up bud! :D
  17. Laine
    Laine This and that
    14 Dec 2010
    Thank you, Pranja! :)
    Mini-ITX is a charming platform to start on, indeed! :)
    Thanks, man!
    Thank you! I'll see what I can do. ;)
    Thanks, mate! :thumb:
    Part III:II
    This time, sleeving!
    MDPC-X; White - Titanium Grey - Color-X.
    And a sneakpeak of what will be pumping through the system.
    See you all on Monday!
  18. kicklOp
    kicklOp What's a Dremel?
    27 Dec 2011
    Excellent! :D
  19. Laine
    Laine This and that
    14 Dec 2010
    Cheers! :)
    Part IV:I
    Placed the backplate on the GPU just to get a preview of what's to come, looks pretty.
    Got caught in the moment.
    And the real reason that we're here, removed the original +12V lane and GND from the PSU and made new ones directly from the PCB since the original was already split and split again, beyond saving. Sleeved the whole thing to match the rest.
    Stay tuned for part IV:II, somewhere near you soon!
  20. Laine
    Laine This and that
    14 Dec 2010
    Part IV:II
    Haha, it's pretty dead in here, eh? :worried:
    Started working on a midplate/floor to separate the pump/res area from the rest of the case, making it look less cramped.
    It took 3 tries and a lot of time, using only hand tools. The powertools just ripped it apart.
    This might give you a better idea of what's to come.
    As usual, don't be afraid to comment or criticize. Next part will be up soon I hope!
