Case Mod - In Progress Inet 001 - Codename Mono - Final pictures!
Discussion in 'Project Logs' started by Laine, 31 Mar 2012.
  1. Guest-23315
    Guest-23315 Guest
    I do love a good WC'd SFF build :thumb:
  2. kelmannen
    kelmannen New Member
    5 Feb 2011
    like like =) is the holes placed so it'll go directly to the gpu with pipes and not hose? water cpu-(rad/pump-)floor-gpu-floor-(rad/pump-)cpu?
    or am i way of? im following... =)
  3. Mr.Evil
    Mr.Evil New Member
    7 Feb 2012
    Though usually I don't like water cooled pc, your project is simply amazing :D !
    I really like the black and white theme with a touch of red, then, I love ITX size :rock:...
  4. Laine
    Laine This and that
    14 Dec 2010
    Who doesn't? :hehe:
    You got that right, but the order is res-pump-floor-gpu-floor-floor-120rad-cpu-140rad-floor-res. :)
    Thanks!
    Thank you! :)
    Part V
    I'm back after a short break, let's continue!
    Fitting of the midplate and the GPU together, the midplate is a bit off centre by the GPU's unsupported weight, making the crystal link a bit tilted.
    The GPU block had its first encounter with the dremel, still a long way to go for a perfect fit.
    See you guys soon!
  5. B.o.B
    B.o.B New Member
    17 Apr 2012
    Very stylish and clean build so far. I love seeing these kinds of builds in a small case!
    sub'd :rock:
  6. KidMod-Southpaw
    28 Sep 2010
    This is just, amazing! Love every aspect of it! :thumb:
  7. Kranik
    Kranik New Member
    21 Aug 2011
    This is a fantastic project. Great inspiration for someone that wants to make a m-ITX water cooling build after a build in a Phantom! It's perfect!
  8. rak500
    rak500 Member
    22 Aug 2009
    That is a very tight fit! I really like the midplate idea!
  9. SkyThread
    SkyThread New Member
    23 Apr 2012
    Looks very good, but I'm wondering if you will get enough cooling for it.
  10. AT0MAC
    AT0MAC Pirate Captain
    8 Jun 2008
    Maybe you can help me, I wonder what the height is of the case without the feet on? I want to buy this and place it under my TV were I only have a height of 30cm
  11. Fonne
    Fonne New Member
    9 Oct 2010
    That rad + fan combo looks amazing :jawdrop: ... A shame they dont really got any static pressure, but the look is soooooo nice :D
  12. Laine
    Laine This and that
    14 Dec 2010
    Thank you for the sub! :)
    Thank you, sir!
    It's been a long time now, did you get around to making it? Cheers! :)
    Thank you!
    To be honest, I don't know. I think it comes down to the overclocking. I did some calculations and it seems to work out, I had another set of eyes on it and he agreed but I really don't know until it's up an running.
    Sorry for the really late answer, but the height is 31,5 cm.
    Hopefully I can get enough out of it, but we'll see!
    Part VI
    It's been a loooong time since I last stepped into this thread, that plus a midset break or what ever you would wan't to call it, for school I'm back to finish what I've started.
    As she sits!
    [​IMG][/IMG]
    Here's where I will put a 20mm fan.
    Or a fillport!
    Got myself a pair of wedding rings for that sweetheart.
    Flush!
    Kind of tight, hopefully it will do.
    Halfway finished with the front radiator mount.
    SSD-holder with two yummy GT-disks.
    Threw the radiator on there, starting to look like something.
    Again, starting to look right!
    The rear, lots of work to do here still.
    It's not as bad as it looks to be, one set of wires are not yet sleeved, and the others need a good stretch, but it will look better once the PSU-shroud is on.
    Test mounting!
    What do we think?
    No longer a 460!
    Lowered the entire reservoir about 5mm, through the floor.
    Hopefully I'll be back really soon to update you guys on progress.
  13. jrs77
    jrs77 Well-Known Member
    17 Feb 2006
    Let's talk about tight spacing between components :p
  14. Sissilisko
    Sissilisko New Member
    26 Apr 2012
    Im in love... with you're case.... and you're skills :D that is THE most tightest **** ive ever seen :D please, show me more... sensei.
  15. Laine
    Laine This and that
    14 Dec 2010
    Typing this with only one hand, kind of got the other one stuck. :-D
    Wow, thank you so much!
    Just because you two are so kind and welcoming, you get another one!
    Part VII
    I got an Aquaero as some sort of "main central" of all the mechanical components. But it doesn't fit! Just 1mm to tall, shouldn't be a hard fix though.
    Also mounted a water temperature gauge/reader to utilize more of the Aquaero. Since last time the rad support in the front was painted, pump wire lengthened, the fan wires resoldered and shortened, as well as shortening the probe wires and USB. Don't worry, all connectors will be painted.
    Oh, and I also made some splitters for the molex lines, and finished off the sata-power. It still needs some fine tuning though, as you can tell.
  16. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    Coming along nicely :)
  17. Parge
    16 Jul 2010
    I'm not sure what I like better, the mod or the photography!
  18. Guest-23315
    Guest-23315 Guest
    A cracking little project, thats for sure. :thumb:
  19. craig - toyoracer
    craig - toyoracer Member
    1 Mar 2011
    Great to see this back in progress mode :)
    It's all in the details and you have soooooo many :thumb:
  20. Laine
    Laine This and that
    14 Dec 2010
    I'm glad you like it, Zen!
    I'm not sure I want to know! Haha! :-D
    Thank you, Mankz!
    It's nice to be back. It's hard to get it the way I want to, and it's so time consuming because of the space, or rather the lack of it. Thank you as always, Craig!
    Part VIII
    Windowtime! Also got working a bit more on the two-tone paint.
    Marked areas will need some love.
    And some nicer shots, because I finally found some time for it.
    It came out pretty good in my opinion.
    Now I'm off to work some more on this! Until next time, thank you for following. :)
