Education information needed
Discussion in 'General' started by weasal, 6 Dec 2007.
  1. weasal
    weasal What's a Dremel?
    22 Jul 2007
    hi
    im starting my case study for advanced higher technology and it is a comparison between normal HDD and SSD. i have looked at howstuffworks and wikipedia aswell as having a read of an article here on bit-tech. how stuff works has info that is oldish as it says the average pc has 10-40GB HDD and not much on SSD.
    i was wondering if you know a good place to get information or if you could send me any.
    i also need information about the materials used
    thanks in advance.
  2. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    google "NAND flash". That's the tech used in SSDs. the fundamental tech used in HDDs hasn't really changed much bar different bearing tehcnologies and faster motors/more cache, although you may want to research perpendicular recording a little, as well as maybe discuss the differences between PATA/SATA.
  3. <A88>
    <A88> Trust the Computer
    10 Jan 2004
  4. liquid_gen
    liquid_gen What's a Dremel?
    12 Feb 2006
    Any information in particular?
    Advantages/disadvantages? If so I'd say the biggest advantages of SSD is that they are faster, and because they have no moving parts are less prone to damage. However, they are more expensive and have a limited number of write operations (not sure about numbers though and therefore how much of a problem this is)
  5. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    The write limit isn't a problem. The number is pretty big and the firmware constantly moves the location of bits written so one bit isn't written to more often.
    It'll last longer than a HDD, that's for sure.
    A disadvantage is that data density is not as high as magnetic storage.
  6. weasal
    22 Jul 2007
    the study basically has 2000 words to describe the 2 items in as much detail as possible and then 500 at the end to compare the features.
    im fairly sure about the info for the comparison so its mainly the main description of the devices.
  7. liquid_gen
    12 Feb 2006
    Well I think wikipedia would be a good starting place and then the external links on the articles.
  8. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    unless you have to state where you got your information from. I don't know about you, but we aren't allowed to use Wiki as a source as it isn't factual (so to speak)
  9. weasal
    22 Jul 2007
    i was allowed to use wiki last year when i did higher although my friend who is doing higher this year said that she wasnt allowed to use wiki so im doubting to i will be allowed to use it.
  10. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    A good Wiki article has references at the bottom (how did you not notice?).
  11. weasal
    22 Jul 2007
    i have noticed but have never had used them that much and i have only had about 5 minutes on wiki lookin at the HDD and SSD info so havent looked at the external links for them
  12. Techscanner
    Techscanner Just Passing Through
    7 Dec 2007
  13. cpu121
    cpu121 What's a Dremel?
    25 Nov 2003
    Look up manufacturer websites. Most will probably have white papers with detailed technical information about the technologies used. Certainly when I did Advanced Higher that was the level of reference they expected for top marks. Of course you need to ensure that it is balanced and unbiased (unlikely if it mentions lots of trademarked technologies!) so see check if there any aritcles that disagree with the conclusions.
