Electronics infra red remote start.. is this possible?
Discussion in 'Modding' started by Springs, 15 Jan 2005.
  1. Springs
    Springs Boing boing
    29 Aug 2004
    i was woundering if its possible it make a remote start system with an infra red setup... ive seen remote starts done with door bells but im curious if it can be done with infra red...?
  2. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    should be simple... depends on how "secure" you want it... You could just connect a photodiode on the mobo pins for the power switch... However this will make it sense all cinds of IR light. And it will turn on with any cind of IR light. The problem is that if it get signals when the comp. is already turned on it will turn of again :duh:
    This could be solved with a couple of resistors and a wire from the +5v supply...
    If you want it to react on a spesiffic signal from a spesiffic remote it will get a bit harder...
  3. Springs
    Springs Boing boing
    29 Aug 2004
    it would be better if it would react to only the remote button...
  4. I'm_Not_A_Monster
    I'm_Not_A_Monster Hey, eat this...
    22 Dec 2003
    I"ve seen mods where someone used a doorbell to mod a switch, but an IR phototransistor and an IR LED would work, but i would modulate the signal to prevent random startups.
    Oscillator (this would be the remote)
    this would be the receiver (instead of the red LED, connect in parallel with the power switch)
    if I'm not mistaken, the Sharp GP1U5X IR Detect Module could be used as the receiver. connect Vcc and Gnd to their proper locations, and output to a transistor (you'd have to figure NPN (High) or PNP (low), it should tell you what the output does when it's activated.)
    if you need any more help i'd be glad to help as much as i can :thumb:
  5. Springs
    Springs Boing boing
    29 Aug 2004
    so those 2 circuits should make it work???
    if so ill have to make a list of parts and look around for them..
    i think i get the shematics.... never have neem good at reading them.. :( i usally get by tho..
    also the only problem with infra red is that u have to have line of sight with the 2 devices... and with those door bells u can be quite a distance for it to still work..
  6. I'm_Not_A_Monster
    22 Dec 2003
    download ExpressPCB
    i'll have a present for you in a little while...
    what voltage/current do the power switches handle?
  7. I'm_Not_A_Monster
    22 Dec 2003
    crap! whats your email?
  8. Springs
    Springs Boing boing
    29 Aug 2004
    oh soz... went to bed after the last post...
    email: eagle35 (at) gmail.com
  9. Springs
    Springs Boing boing
    29 Aug 2004
    ok ive only been able to look at the scematic in more detail...as ive been a bit busy lately..
    looking at the reciever... i no its for a "infrared" tester.. but wouldnt i just be able to wire up the infra red reciever straight to the power switch? i dont think it really need power does it? the motherboard supplies a little bit of power throught the contacts for it to start up...???
    im not a total electronics wizard so i dont no exactly what is what.. :( but i no my basics (sorta)
  10. I'm_Not_A_Monster
    22 Dec 2003
    did you get my email springs?
  11. Springs
    Springs Boing boing
    29 Aug 2004
    yes i did thanks for that...
    i was just thinking about the design of that circuit.. im not sure that it would need that power... i think its mainly for the LED?
  12. I'm_Not_A_Monster
    22 Dec 2003
    if you're talking about the IC and LED's on the remote, remember that it's +5V, meaning you can have +2.5V, the LED's are in parallel, so they draw whatever voltage and their own current, and the 555 needs some power to operate.
    three AAA's in series will do the trick (1.5V X 3 = 4.5V)
  13. Springs
    Springs Boing boing
    29 Aug 2004
    ooops i forgot to say i was talking about the reciever.. and not the remote
  14. I'm_Not_A_Monster
    22 Dec 2003
    worst that'll happen is you'll need to sacrifice a molex
    ps, maybe just get a slice, like what are on the end of fans, plug molex in unit, plug unit into drive
  15. Springs
    Springs Boing boing
    29 Aug 2004
    thats not really a problem got sooo many lying around..
    one thing i forgot to ask is what sort of range will i get with this?
  16. I'm_Not_A_Monster
    22 Dec 2003
    mpja.com has a kit for making this, they say that the distance is pretty good, you'll be able to start the PC from your front door when you walk in. maybe from the driveway
  17. Springs
    Springs Boing boing
    29 Aug 2004
    do u have a direct link by any chance? its easyier than trying to search through it all
  18. I'm_Not_A_Monster
    22 Dec 2003
    transmitter
    receiver you probably already know this, but to anyone else, wire it as normally open
  19. Springs
    Springs Boing boing
    29 Aug 2004
    hmm shame its in another country and one of them is $15 :(
    have to find somewhere in the UK that might supply em
  20. I'm_Not_A_Monster
    22 Dec 2003
