Scratch Build – In Progress inFusion by Smasher [Scratch Build] [Finished]
Discussion in 'Project Logs' started by Smasher, 3 Jul 2012.
  1. Smasher
    Smasher What's a Dremel?
    4 Jun 2011
    inFusion
    The project infusion is a Scratch Build case that will be builded from the beginning with different types of materials: Acrylic, Metal and Wood.
    Have a unique shape and design, containing in it a powerful hardware.
    Have a watercooling (Corsair H50) modified for this project.
    The aesthetic is warm hug, with around 183 hours dedicated solely and exclusively to this design.
    These will be the base material will be used:
    Samples of acrylic, acrylic tubes, and sheets of old cases.
    With this cover of old cabinet, the main structure will be built.
    Based on a test piece made of cardboard, the cuts are marked.
    Starting!
    Filing the edges and sand the paint to make the raw metal.
    With this piece semi finished, we will build the front, which will house the hard disk and DVD lectograbadora.
    While I Twitcam
    With the heat gun to bend the acrylic we have left to 90 °.
    Now the sides of this piece, also bent with the heat gun.
    Las piezas se pegan con cloroformo industrial, diluido con acrilico para darle una consistencia espesa y que no se evapore tan rapido.
    The rough edges that will be sanded.
    Más de la estructura principal.
    I had the problem that the acrylic is encompassed by a lot of heat, so should replace this piece.
    Now yes!
    The "cap" where under DVD.
    Adding an acrylic to add rigidity.
    Through which pass the wires from the HDD and DVD.
    Submission:
    From one side of cabinet manufacture it a holder for the source:
    Screws and mother presented.
    VGA:
  2. Smasher
    4 Jun 2011
    Well after a while I return with much progress.
    I was at an event, in Loki Custom Tech stand, exposing White Timantti, photos of the event here:
    Web
    In this joined Kingston as Sponsor, providing a HyperX 2x4GB DDR3
    and 110gb.
    We continue to progress, stand to tighten and not have to go with glue:
    And set the psu support:
    Support for the base:
    Cut cut cut
    PSU
    "Knockouts" where they will spend the sata and power
    Ventilation to go with metal mesh
    Now we start with the "box" of the motherboard
    This is a side project, will modding on these pc's, can follow the project on
    www.facebook.com/SmashModding
    Sides
    Small window on a single pass of the power cables
    Old cabinet veneer, thick as a good basis for
    Presenting
    Support for HDD's
    Re-do media
    i/o Panel
    Window-mesh
    Support structure
    Good and so is at the moment, I hope your opinions!
  3. mybadomen
    mybadomen What's a Dremel?
    19 Jan 2012
    Looking good. I always love the Raw Modding. Thats all i did for years as i had old machines and no money. So i love seeing this stuff! Shows major talent. Look forward to seeing what comes from you in the future.
    MybadOmen
  4. Marcos_Viegas
    Marcos_Viegas Minimodder
    6 May 2010
    Really is a very good idea, I'm enjoying the project, congratulations!
  5. Enigma8750
    Enigma8750 What's a Dremel?
    13 Jul 2011
    Beautiful Artwork Smash....
  6. KryptiK
    KryptiK What's a Dremel?
    12 Jan 2012
    That's one bad ass looking design you got there! :rock:
    Wondering what colours your going to spray it with? (if you are going in that direction)
  7. Smasher
    4 Jun 2011
    Thanks!
    Thank you dude!
    :3
    Well, still do not know what colors... Im thinking about violet, black or blue... What do you say?
    Here more:
    Well I have a few developments
    I worked all part of the radiator
    And went back to do the HDD bracket because on the other, the bottom had no room for the cables:
    And I started a small reservoir for H50, lack seal:
    regards!
  8. dbradford32
    dbradford32 What's a Dremel?
    22 Aug 2010
    OMG! THIS IS AWESOME! Seriously, this is genius! Keep it up!
  9. Ace_finland
    Ace_finland Minimodder
    11 Aug 2012
    this is just great! i love acrylic builds!
  10. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Great work :thumb: Subscribed
  11. Smasher
    4 Jun 2011
    After a while of modding, progress:
    Modification "box" of the PSU:
    And finally paint!
    Ready to paint
    Was something like:
    VGA Cover
    Fans:
    Painting on the VGA:
    PSU Sleeving:
    This source is unique in this topic:
    Which would not let me do sleeving 1x1, cut extensions.
    Santi approves the project!
    Scratch Build finished paint job
    As we continue with the cables:
    Starts assembly!
    And the mini reservoir of H50:
    In a little while final photos!
  12. Smasher
    4 Jun 2011
    Finished Project.
    Hardware:
    Intel(R) Celeron(R) CPU G530 @ 2.40GHz, 2394 MHz
    ATI Radeon HD 4870 1024MB GDDR5
    Kingston 2x4GB DDR3 1600
    PowerCooler 850w 24+4 Pins Home Made Sleeving
    GA-H67N-USB3-B3 - GIGABYTE
    SSD Kinston Hyper 110gb Sata3
    WD Caviar Blue 320gb
    WD Scorpion 320gb
    Facebook: http://www.facebook.com/SmashModding
    Web: http://www.smasher.com.ar
    YEHBABY likes this.
  13. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Fantastic job. Well done! :)
    Can you post more pics so we can see how you modded H50?
  14. Smasher
    4 Jun 2011
    Thanks!
    Those are all the photos: (
    Only cut original hoses and build a reservoir! :)
