Inner radius of hardtube bends
Discussion in 'Watercooling' started by Vognen, 20 Apr 2018.
  1. Vognen
    Vognen Minimodder
    2 Oct 2013
    I'm doing some loop planning, and in order to make everything look its best, I need to take tubing into account. I've searched a lot on the world wide web, but I can't seem to find any information.
    I'm going to be using 12/10 tubing. What's the smallest/tightest bend I can make without the tube collapsing on itself?
  2. TechnoMod87
    TechnoMod87 What's a Dremel?
    13 Nov 2012
    probably 4-5 cm
  3. TheMadDutchDude
    23 Aug 2013
    The tightest bend will only be possible with fittings, otherwise as above. I reckon you can get it a little tighter, but I’m not experienced with it.
  4. RedFlames
    23 Apr 2009
    IIRC 2x the diameter of the tube is realisitcally as tight as you can bend most tubing without having to use mandrels or the like...
  5. Vognen
    Vognen Minimodder
    2 Oct 2013
    Thanks a lot for the answers. I might have to look into buying some L-connectors then :)
  6. LePhuronn
    LePhuronn Minimodder
    6 Oct 2016
    I 3D printed some mandrels to get a 16mm centerline radius out of 12mm acrylic tube because I need some ungodly tight bends but don't have the space to use 90 degree fittings. That makes the inner radius 10mm. I need to make a few tweaks to the design but it works for the most part.
    To get that tight though you need the bending cord inside to be very flexible. Originally I used 9.5mm diameter nitrile cord but in itself it doesn't bend tightly enough, so I swapped to some silicone fuel hose with (I think) a 3mm wall. That bends tightly.
