News Inno3D announces GTX 470 Hawk
Discussion in 'Article Discussion' started by CardJoe, 11 May 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Well, given how much larger it is, if it didn't cool better and quieter Inno3D can fire their engineers.
  3. mi1ez
    mi1ez Modder
    11 Jun 2009
    Given the noise and temperature of Fermi, I think we'll be seeing a lot more custom coolers!
  4. cgthomas
    cgthomas Cpt. Handsome
    20 Oct 2009
    I'll get one if it's in the £270 range
  5. scott_chegg
    scott_chegg Minimodder
    16 Feb 2010
    Think you'll be looking at over £300. Prices on Scan at the moment are from £281 to £343. With a custom cooler it'll probably sit in the higher end of this range if not above.
  6. javaman
    javaman May irritate Eyes
    10 May 2009
    Is it possible to do SLI on a triple slot cooler card? If so do this with the GTX480 and it might be worth considering but until the GTX470 is reduced in price its just not worth it.
  7. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Looks like an Arctic Cooling solution. Inno has done "custom" coolers with them in tha past.
  8. ripmax
    ripmax Minimodder
    8 Apr 2010
    That's one large cooler, better be good at cooling for the price.
  9. Spanky
    Spanky Multimodder
    14 Apr 2010
    Had a 4870x2 recently, thought id splash out on the posh triple fan cooler, £60 notes later a VERY cool 4870x2, whisper quiet .... oh yeah i had to spend another £30 to cool the bloody case down cos now all the massive heat was being blown strait into the case .....
  10. stivalmighty
    stivalmighty What's a Dremel?
    11 May 2010
    Looks sooo good. wonder what the price will be.
  11. crayfish
    crayfish Amazing scenes!
    3 Dec 2002
    That's absurd.
  12. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    yes if I remember it was designed by AC and distibuted to Inno. Look on the bright side customer coolers have well sorta gone to the way side as for a while the stock coolers did a decent job but thanks to Fermis horrible design its bring custom coolers back so in away it helps bring those companies back up. :)
  13. Krayzie_B.o.n.e.
    Krayzie_B.o.n.e. What's a Dremel?
    2 Aug 2009
    This is just too costly as all the heat that use to flow out the back of your case will now flow right into your case and raise the temps of your overclocked CPU. I think Nvidia is forcing people to take out Bank loans to watercool a high end Core i7/ Fermi rig.
  14. DBA
    DBA I do my modding with a spoon
    18 Feb 2009
    green PCB!?!
  15. ssj12
    ssj12 Minimodder
    12 Sep 2007
    I hope EVGA makes a custom 470/480. Or Nvidia respins them and adds a 475/485.
  16. Xkaliber
    Xkaliber What's a Dremel?
    12 Dec 2008
    Currently sitting at £268 on Ebuyer.com, grabbing one as we speak.
Tags: Add Tags
