Inno3D GeForce 7950 GT
Discussion in 'Article Discussion' started by Tim S, 23 Oct 2006.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    Random question: What were memory temps like? The 7950 GT cooler's I've seen include pads for the memory, I'd be worried about overheating with the Inno3D solution.
  3. Tim S
    Tim S OG
    8 Nov 2001
    Artifacting is usually a problem when memory overheats - the card was perfectly fine to be honest. The DRAMs were warm to the touch at best (or worst) - many 7900 GT cards had the memory running without heatsinks in excess of 1500MHz, so I don't personally see it as much of a problem. Memory heatsinks will of course help you over time but this seemed to cope well through a stress test. :)
  4. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Iss it just me, or does it appear that Inno3D (for some reason unbeknowenst to man), has drilled out two holes on the PCB just a little shy of the reference mounting holes, and done so on the cooler too?
  5. Guest-2867
    Guest-2867 Guest
    No it's not just you, they probably just wanted the cooler to cover the entire core
  6. LoveJoy
    LoveJoy What's a Dremel?
    22 Apr 2006
    Hmmm it's kind of wierd that few blocks get better results on Nvidia than Ati everytime. Wonder if its all about the HW that they use...
  7. mclean007
    mclean007 Officious Bystander
    22 May 2003
    Not sure I follow???
  8. Tim S
    Tim S OG
    8 Nov 2001
    I'm lost too :)
  9. specofdust
    specofdust Banned
    26 Feb 2005
    Looks like a good card, but for £60 over the 1950Pro it doesn't seem worth it when the performance looks to be so close.
    /me wishes the 1950 pro's would make an appearance
  10. Tim S
    Tim S OG
    8 Nov 2001
    Pretty good, as they say. ;)
Tags: Add Tags
