Hardware Inno3D iChill GeForce GTX 275 Review
Discussion in 'Article Discussion' started by Guest-16, 15 Jul 2009.
  1. Guest-16
    Guest-16 Guest
  2. DragunovHUN
    DragunovHUN I want to change my name but I also don't
    30 Oct 2008
    Holy mother of god!
  3. flibblesan
    flibblesan Destroyer
    27 Jul 2005
    On the Crysis page you put "MSI GTX 285 HydroGen OC" scores instead of the Inno3D card. Second down.
  4. bahgger
    bahgger New Member
    13 Apr 2005
    I want that graphics card cooler..
  5. Elton
    23 Jan 2009
    It would be much cheaper to just slap on the cooler yourself.
    Interestingly the cheapest GTX275 is over in the US is 124 pounds.
  6. Aracos
    Aracos New Member
    11 Feb 2009
    lol not everyone buys cards with non reference coolers for overclocking, I don't care much for VGA card OCing because it's mostly never a decent boost in performance for high end cards, I just don't want my card running at 80C :jawdrop: but yeah it's fairly overpriced, for that performance I'd just get a 4850X2 for £134 (latest scanshot) and get some aftermarket coolers for each GPU (thank you thermalright :D).
  7. Guest-16
    Guest-16 Guest
    There's no reason why it can't run at 80C as long as it has a good warranty, it's very quiet and it does not affect stability - that's how Nvidia designs its cards. Temp only affects overclocking and as long as you're not overclocking you'll probably be more concerned with keeping the noise down. The IChill is better under load, without doubt, but at idle the stock cooler is already very quiet.
  8. Aracos
    Aracos New Member
    11 Feb 2009
    I'm a believer in higher heat = less life span so that's why I choose heat over anything, I think it's unacceptable that nvidia and amd release products that reach 80C+ but I would just buy a cheap stock card and put the cooler on it anyway.
  9. azrael-
    azrael- I'm special...
    18 May 2008
    I'm confused. Is that a criticism of the Palit/Gainward GTX275 or the opposite? I'd always had the impression you liked how they customized the card.
  10. Guest-16
    Guest-16 Guest
    It was cost down. The power circuitry was minimised for less overclocks but it was also lower power and cooler too (because it took more space).
  11. azrael-
    18 May 2008
    So unless I would want to overclock the Palit it's still one of the GTX275 cards best to get? Shame you didn't test the Palit against the Inno3D with regards to heat and noise (performance-wise I don't think there's too much to gain).
  12. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    something on the brain, rich?
  13. tejas
    tejas New Member
    30 Sep 2008
    I would much rather have cheaper and better overclocking reference 275s than this hulking monstrosity. What is it with these third party coolers and lack of memory cooling?? Its all very well with the GPU in the 30's at load, but it cannot be good for the VRAM to get low second hand airflow.
    In fact there is no way that would fit inside my Antec 902.
  14. Guest-16
    Guest-16 Guest
    I was wondering how long it would take for someone to notice :D:D
  15. Tyrmot
    Tyrmot New Member
    12 Mar 2008
    I got one of these accelero Xtremes for my old 8800GTX and it was awesome. It wasn't too hard to fit either so maybe given the cost of this you'd be better off finding a cheap stock 275 and buying the cooler separately. I imagine that would make the price/performance ratio a little more favourable
  16. Jojii
    Jojii hardware freak
    12 Dec 2007
    You could use the card as the basis for a voltage mod article.. or do you have to give the card to somebody else? too bad really, for something that elaborate.
  17. Fisher.
    Fisher. partially impartial
    21 Jan 2009
    That is fast!!! :lol:
  18. Fazed
    Fazed Active Member
    5 Jul 2009
    lol....Article published on the 15th of July, click on the link to Ebuyer's website and they have already discontinued it and it's no longer available for sale!!
    What gives??
  19. Guest-16
    Guest-16 Guest
    Inno3D UK distribution Failure.
    We held off on the review because they promised UK availability. Eventually Ebuyer listed it.. pending stock, which Inno said would be available at the time of the review going live. It seems Ebuyer decided not to restock after selling the small batch they got.
    Fixed ta.
  20. Fazed
    Fazed Active Member
    5 Jul 2009
    Bah!!
    Been waiting for a GTX275 with a customer cooler to surface in the UK.
    Zotac , TwinTech and Galaxy are all offering the GTX275 with the AC Cooler pre-fitted, but I can't source one in the UK!
    Guess I'll just have to bite the bullet, get an Asus from Scan for £150 and slap the cooler on myself. Will save a few quid too....I'm just bone idle!!
Tags: Add Tags
