Electronics Input Device
Discussion in 'Modding' started by nry, 1 Nov 2006.
  1. nry
    nry Minimodder
    1 Nov 2006
    I use to be a member here, but have no idea what my old username was, and I no longer use the email address that I used before, so I started a new account :blah:
    I am planning on putting a pc into my car, with a 7" touchscreen, but I also want a input device for scrolling.
    Basically what I want is like on the BMW m5 (was on topgear once) where you turn a knob to scroll through options, and you can push it down to select.
    I have seen a guide like this on the internet before, just dont know where, had a feeling it was here, but couldnt find it?
    :jawdrop:
  2. JCG
    JCG What's a Dremel?
    1 Dec 2005
  3. Hiren
    Hiren mind control Moderator
    15 May 2002
    Use a Griffen Powermate?
  4. JCG
    1 Dec 2005
    where is you modding spirit? :p
  5. nry
    nry Minimodder
    1 Nov 2006
    Ah thats it :)
    Im on a tight budget :p, got more important things to spend my money on, thats all.
    Also if i didnt go out so much it wouldnt be so bad :wallbash:
  6. shotgunefx
    shotgunefx What's a Dremel?
    4 Feb 2004
    If you haven't already, check out the forums on mp3car.com
    An alternative route (which I took), I got a cheap thumb mouse, some hacking, expoy and lot's of sanding and I came up with this.
