Electronics Inspiron 5150 Internal LCD Connector pin out
Discussion in 'Modding' started by jtarpley, 5 Sep 2006.
  1. jtarpley
    jtarpley What's a Dremel?
    5 Sep 2006
    I have come in possession of an Inspiron 5150 with the now infamous DC jack issue. The LCD panel works fine, and I have decided to use it in a case mod I am planning. However, I do not know the pin out of the connector that clips on the video card. I was hoping someone could point me in the right direction on how to find out what it is, or if it is standardized.
    Cheers,
    Jason
  2. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    I have read if memory serves me...That those Laptop LCd displays are incompatible with a normal graphics card.
  3. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
  4. jtarpley
    5 Sep 2006
    Thanks for the info, there is a link to EarthLCD in that thread you linked to.
    It seems I will need to buy a controler card from them to get it to work, probably close to 200 USD.
  5. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    wouldn't it just be cheaper and easier to buy a new lcd with vga/dvi inputs and take that apart?
  6. kbn
    kbn What's a Dremel?
    17 Mar 2004
    I remember reading that old graphics cards have a vesa connector (10x2 row of pins or something), which you can connect with a laptop lcd... but its limited to something like 8bit colour depth...
    I dont know the pinout but should be easy to search for..
