Windows Installation of Windows
Discussion in 'Software' started by Kovoet, 18 Jun 2014.
  1. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Just a question could I install Windows with an external DVD drive via the usb.
    Thanks in advance
  2. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    yeap that should work, provided your board supports usb cd/dvd boot
  3. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    What he ^ said. I've had to do it a couple of times and I didn't encounter any issues.
  4. Teelzebub
    27 Nov 2009
    Yeah done it the other day on a netbook that way all I had to do was bring up the boot menu while booting and select the DVD
  5. Kovoet
    26 Aug 2009
    Thanks guys.
  6. sonicgroove
    sonicgroove Radical Atheist
    16 Mar 2011
    Th best (and fastest) way I have installed Win7 was with a usb stick to a SSD. It took under 7 minutes from start to finish.
  7. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    ^this is how we used to do it in my last place of employment, it was surprisingly quick. I don't think it was as quick as 7 minutes but we were using USB 2 and i3s with relatively entry level boards.
  8. Kovoet
    26 Aug 2009
    Can I just do a copy and paste Windows files from CD to usb stick
  9. sonicgroove
    16 Mar 2011
    use this and download an ISO from digitalriver(totally legit btw) Follow the instructions and you will be up and running in no time. It's totally foolproof. Just remember to change the boot order in the UEFI/BIOS
  10. suragh
    suragh Derp
    26 Nov 2011
    If you run in to any sort of trouble with the microsoft tool, Rufus is an alternative.
  11. Kovoet
    26 Aug 2009
    Awesome guys thanks. Attempting after breakfast
  12. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Optical install is so much slower. Even taking the time to prep a usb stick then install is still less than half the time it takes. I prefer using rufus anyway, especially if you have a uefi system so you can make absolutely sure it will do a uefi/gpt install instead of legacy bios/mbr.
  13. Kovoet
    26 Aug 2009
    Thanks and yes so much easier. Optical drive put away in the cupboard forever and will keep the external one for an emergency.
  14. IvanIvanovich
    31 Aug 2008
    haha. Yeah optical has been dead to me for ages. I stopped putting them in PC starting in 2007 or something like this. I don't even have an external optical for some years.
    I even figured out how to install Windows 98 for my retro gaming box from usb stick! Some crazy trickery on an OS that was barely aware of usb in the first place LOL.
  15. BadHead
    BadHead Minimodder
    16 Feb 2004
    Provided its not Windows XP. That has trouble with anything other than an internal Optical Drive. I tried it once and it did nit work. I'm not saying it's impossible, just that you may have to jump through a few more hoops to get it to work correctly.
    Sent from my Nexus 7 using Xparent Skyblue Tapatalk 2
  16. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    Optical dead? Nah, not for me, still have a Bluray Writer.
    Kov, as many have already said, the USB option is very elegant. :D
    Been using that method myself for a while now as the install seems to take around 8-10 minutes onto a SSD, well around there.
    Will also make a note of RUFUS, wasn't aware of that tool, so thanks guys!
