Installing a new fan
Discussion in 'Tech Support' started by GenerationX, 17 Jan 2008.
  1. GenerationX
    GenerationX What's a Dremel?
    9 Dec 2007
    I'm back again for more help..:D
    I've been trying to install a fan that says it's for the PCI Slot (which I assume means that it pokes through the metal bits at the bottom of the case, under the I/O shield) but the bloody thing just won't go in.
    Anyway here's a pic of the offending item
    LINK
    http://img112.imageshack.us/my.php?image=fanje6.jpg
    Any help would be great. Cheers
  2. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    the metal prong on the left of that product looks like it would screw into the SIDE of the PCI brackets one screw in each U-shaped channel at the top and bottom so the fans would be blowing across the PCI cards in the slots that it covers.
    Hopefully that makes sense
  3. GenerationX
    9 Dec 2007
    None at all. Can you post a picture of the bracket?
    Thanks
  4. badders
    badders Neuken in de Keuken
    4 Dec 2007
    You know the screws that hold your PCI cards in?
    Take 3 adjacent ones out, and put them in the 3 holes in the metal lug on the left side of your picture.
    Lift the whole assembly up so that the 3 screws will go back in their holes, while still staying in the holes of the metal lug on the fans.
  5. GenerationX
    9 Dec 2007
    By the way you're making this sound I need another bracket?
  6. culley
    culley What's a Dremel?
    12 Jul 2006
    Like that.
    You need to put the u shaped holes underneath the screws which hold the expansion cover slot or cards.
    EDIT:
    The red parts are screws.
  7. BioSniper
    5 Feb 2002
    That's what I meant!
    My explainations are sadly rather terrible, and I'm really only hazarding a guess at any rate but it looks about right.
  8. badders
    4 Dec 2007
    Lookat the picture you posted of the fans. See the bracket on the left?
    Look at the bit inside your case where the PCI cards go. See the screws down the side, that hold the cards in?
    Now follow previous instructions.
    No Brackets needed. You have everything you require.
  9. GenerationX
    9 Dec 2007
  10. culley
    12 Jul 2006
    From inspecting your case, I think you will need remove your USB expansion card and stick the fan over the remaining two.
    EDIT: lol I don't think you need any more fans in your case, I'm sure it already sounds like a jet engine.
  11. GenerationX
    9 Dec 2007
    Suprisingly quiet but my temps are still rather high. This just get's more complicated as we go along..USB expansion card?
  12. BioSniper
    5 Feb 2002
    No kidding that your temps are probably high.. just look at that dust inside your CPU heatsink! :eek: I'd really be inclined to give that a clean where possible.
    The plastic ducting probably doesn't do it many favours either as well as what looks like no front intakes.
  13. badders
    4 Dec 2007
    WTF!!!!
    I never saw that the first time!
    Bloody hell, get a hoover in there, quick!
  14. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    A real BTW: I have a PSU with the exactly same sticker than GenerationX has! :D
