Installing a new Power supply. {I'm 15 and don't want to die}
Discussion in 'Hardware' started by gino23, 12 Oct 2006.
  1. gino23
    gino23 What's a Dremel?
    8 Oct 2006
    Hello, I'm thinking of buying a new psu so that I can upgrade to a better video card. Howerver, I am really scared and i don't really know how to do it.
    I have opened my Sony Vaio PC before just to take a look before, but I have never really messed with anything inside.
    I know I can replace the AGP video card and ram easily. (Just plug in and plug out), but the PSU is a different story.
    Can anyone please help me in a detailed safe step-by-step guide in installing a new power supply.
    My specs:
    p4 2.6
    1 gig ddr ram
    ATI radeon 9600xt (upgrading to 7600gt, but I need a new psu).
    300w crap psu.
    The psu I plan on getting is this http://www.newegg.com/Product/Product.asp?Item=N82E16817153023
    It was on the front page of Newegg and an "uber" deal, so I guess its good.
    And also, is that PSU compatible with my motherboard? Sorry I don't know much about PSU compatibility. I don't really know my motherboard, but I would guess its a standard Intel one that most consumer PC's come with.
    thx again
    And one last thing lol. I have an AGP 4x/8x slot, no PCI-express slot. Does that PSU still work with AGP 4x/8x interfaces? I'm just wondering, because on the connecters is a "PCI-E", so dunno.
    Thx alot.
  2. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    NO NO NO NO NO NO NO NO NO NO NO do not buy that power supply. It's Not what you want. For $40, buy the Fortron AX-400. WAY better.
    Depending on your sony vaio case, you may have a very small power supply in there, a micro ATX. If it measures about 4 inches, you may need to mod it. This can be as simple as just ghetto rigging it to the outside with duct tape, or with cutting the case and all.
    Assuming it's full size, you buy a better supply, it's just 4 screws on the back, pull it out, put in the new one.
    If it says PCI-E, that means it can support a pci-e card. It also means you can do AGP, PCI, whatever. It'll be fine.
  3. airchie
    airchie What's a Dremel?
    22 Mar 2005
    Yeah, check the measurements of the existing one.
    Don't worry about electrocuting yourself, all the dangerous voltages are isolated inside the PSU and you can't touch them without breaking the PSU open.
    And yeah, that PSU looks rubbish tbh.
    Seasonic, Tagan, Enermax etc are much better.
    Get one from the above manufacturers that matches the physical dimensions of your existing one, and buy it.
    Then its a simple case of unplugging the old one (taking note of what you unplug) and hooking up the new one to all the places you unplugged the old one from.
    Bosch! :)
  4. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    Actually, for what your doing that PSU is fine. I know someone who has it powering a similar system to yours, it works fine. Although the one the other guy said would probably be better, Thermaltake is not a bad brand from my experience.
  5. gino23
    8 Oct 2006
  6. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    Your PSU link isn't working. but it sounds like you're gonna need 480w+ or more?
    FSP are indeed good PSU's. You'd need at least the 500w model (US$90).
    But Hiper Type-R's are decent enough PSU's as well... and for the same price as that FSP... you could get the 580w [Modular] model.
    I've got three of those in different rigs meself (blue, red + black, to suit the various themes used in each rig :D), and they both look good, and perform well :cooldude:
  7. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    As long as you don't open it up, plug it in and then start licking capacitors, you'll be fine.
  8. Glider
    Glider /dev/null
    2 Aug 2005
    Cap licking modders, who are they, what are they doing, and formost, why are they doing it ;)
  9. gino23
    8 Oct 2006
    Fixed links.
    Wait your saying the x1650 needs 480w?
    I thought the minumum for that card is 350-400w?
  10. Bbq.of.DooM
    12 Feb 2005
    he'll be fine with the FSP AX 400.
  11. Firehed
    15 Feb 2004
    Most people severely overestimate their power needs, so in all reality you can take most suggestions for ratings with a grain of salt. My fileserver runs five hard drives, a DVD drive and whatever core's in the celeron Ds (might be prescott, I've longsince forgotten) plus a number of USB devices including an external USB-powered hard drive all fine on 300w. Mind you I want to stick my old 6800GT in there soon since my proper gaming rig isn't available and I doubt it could handle that (and I'm not risking a terabyte to find out), but a quality power supply tends to go a pretty long way.
    I'd avoid thermaltake PSUs regardless. They're decent enough for the money, but irritatingly loud. I like Antec units myself, but there are plenty of great brands out there.
    As for actually putting in a new one... I've never heard of someone electrocuting themselves doing so. Unless you go out of your way, I don't think it's even possible. What I'd suggest is having it plugged in but the main overall power switch on the back next to the plug set to off, so that it's grounded but not actually receiving any juice. That or fully unplugged if you feel more comfortable, but unless you crack open the box and start touching multiple metal points, you really can't harm yourself. Or at least I haven't, and I've done quite a few PSU installs, and I *have* opened the things up and poked around a bit (do NOT do that unless you know how to do it safely; I do). But all of the semi-exposed metal bits are sheathed in plastic... you're at a higher risk of electrocution just plugging in any ol' plug to the mains outlets, since for a very brief period there's live metal exposed.
    A system of that level will NOT need 500+ watts; I think 400w or so should be enough like Bbq said (well, I'm assuming that model is 400w, going by the 400 in the name). But on the other hand, extra never hurts (unless it's some crap brand with artifically high numbers) and if you need to upgrade the system again later, it's one less component that needs to be bought again.
    Only PSU dimension you'd need to be concerned about is depth, as height and width are industry standard (at least excluding proprietary stuff). And unless you're in the massive 650w+ units, they're all close to the same depth as well.
  12. gino23
    8 Oct 2006
    Thanks alot man :)
  13. mrbungle
    20 Sep 2004
    i think the 7600gt is a far better card than the x1600pro's as well
    the 7600 clock real well too for a extra boost
  14. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    Antec is good, so are tagan, seasonic, enermax. many theraltake are crap but not all, depending on your budget. have no fear u shall not die, im 14 : ) and i have already had 2 dead psu blow and im stil alive ... hopefully
  15. trig
    trig god's little mistake
    10 Aug 2006
    400 watts is fine for what it looks like you are running...that thermaltake u put on there has a pretty low eff rating, but again, for what you are running u are prolly fine...between the two you are looking at id prolly go fortron
