Linux Installing HP-960c printer trouble
Discussion in 'Software' started by Dorza, 8 Mar 2003.
  1. Dorza
    Dorza What's a Dremel?
    8 Dec 2002
    Ok im haveing great diffuculty installing this under Redhat v8. Im following what it says in my RH book but it doesnt work for me. Its telling me to go into the "Red Hat Printer Config" Program. When i get there no printers are listed so i click on new and give the printer a Queue name and cick on LOCAL for queue type. next it asks teh device: /dev/lp0 and /dev/usb/lp0 are listed. SInce im useing the first USB"2" port on my motherboard i select to use /dev/usb/lp0. Next i choose my driver for the printer which is HP> DeskJet 960C> then i choose hpijs(*) and click forward and apply. I then go to test the printer by selecting Test >A4 PostScript TestPage when i do this it comes up saying "There was an error printing the test page". Ive gone through all the availabel drivers listed for my printer and ive tried it on a paralell cable but it still doesnt print. Why the hell isnt it printing? i just dont get it. Could ne one help me with this please. Id be very greatfull. Thanks:)
  2. Kargin
    Kargin Overdose . . .
    18 Sep 2002
    Okay, I had this problem before, I tried everything, yet my printer refused to work. After an hour of ****ing aorund and threatening the Redhat man with a screwdriver, my Mom comes in and does it, I tell her how to do it, as she doesn't know, and she goes through EXACTLY how I did it before. BANG. The printer works fine.
    My advice, get soemone else to do it, doens't matter if they nothign about computers, just tell them where to click.
    Short of that, /dev/lp0 should be your printer. Try rebooting, randomly loging off, etc. Redhat is an evil little man who delights in abusing and raping people.
    Don't forget the screwdriver.
  3. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    HP printers work best with a program called CUPS which auto-loads with the linux kernel, googleize CUPS and read up the documentation on that
  4. Kargin
    18 Sep 2002
    Redhat uses CUPS.
    It is autolaoded.
  5. bee2643
    7 Mar 2002
    hrm
    did u set your printer up throug hthat?
    i think u goto like, http://localhost:80/cups
    or something along those lines, see if its giving u any error messages
  6. Dorza
    8 Dec 2002
    I cant remember if i set one up or not to be honest with you. If im useing a usb2 connection would linux pick it up as usb1? Doesnt linux not support USB2 yet? and owuldnt it be /dev/usb/lp0 if on a usb connection?
  7. Kargin
    18 Sep 2002
    As far as I know, USB2 is just a faster version of USB, but works just like USB1, so Linux should pick it up fine.
    What do you mean your not sure whether you set one up or not ? I thought that was what you were having trouble with, setting upt eh printer, and Linux not using it properly.
    :eyebrow:
  8. Dorza
    8 Dec 2002
    sorry i was confusedwith that post before my last one. ne ways it sitll doesnt work . Ive tried /dev/lp0 and /dev/usb/lp0 and made a new connection and restarted my comtpeur each time i changed somthing, I even changed my USB port but it still doesnt want to work
    I did how ever manage to get my interent working again which im proud of:p :D
  9. bee2643
    7 Mar 2002
    k well its not going to wok if u dont set it up through cups guy
    goto http://localhost:80/ and configure your printer as usb and select the printer it is, etc..
  10. Dorza
    8 Dec 2002
    That linky dun work. it says Connectionwas refused when connecting to local host. :wallbash:
  11. Kargin
    18 Sep 2002
    Make sur eyour DNS is working properly, and also make sure that your machine is called localhost.
    It should be structured:
    http:// <DNS-name-here> : 80/
    By default it's localhost.localdomain I'm not sure if you need the domain as well in there, so . . . . .
  12. Dorza
    8 Dec 2002
    Sorry i havent replied, been busy with college work so i havent really been on linux recently ne way somthing really strange has happend. I loaded into KDE the other day set my printer up like i done in GNOME and Kahbam the printer works now :confused: :confused: very strange creature is linux :) . thanks for ur help guys
