Installing SATA HDD
Discussion in 'Tech Support' started by Tibby, 28 Jun 2006.
  1. Tibby
    Tibby Back Once Again
    9 Oct 2005
    Can someone just give me a quick step by step?
    I have physichally installed it, I am just confused by the jumpers and getting it picked up in Windows.
    It is a Western Digital SATA 250GB.
    Cheers fellas!
  2. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    SATA drives shouldn't have any jumpers.
    And the drives/motherboard should come with a little floppy with drivers on them.
  3. Tibby
    9 Oct 2005
    Is it just a case of installing drivers from the floppy?
    Can I get the drivers from online?
    They do have jumpers for different modes, not for Master Slave.
    Also Windows isn't picking up anything fullstop, is this not kinda weird?
  4. DougEdey
    5 Jul 2005
    You shoudl leave the jumpers as they are from factory, unless you know what they mean so you can change them
    First enable the SATA ports in your BIOS, depending on your motherboard you may have a seperate BIOS come up for it.
    When you get to windows it should say "NEw hardware detected" and ask for raid software, again dependant on motherboard these may be included in your chipset.
    If not, goto the control panel -> admin tools -> computer management and storage.
    See if you can see the drive there, then initialise it.
    You can also use the manufacturers software from their website (or something like UBCD to initialise it before windows boots.
  5. Max Tractor
    Max Tractor Minimodder
    15 Jan 2006
    Samsung sata will ship with jumpers sata 150/300
  6. Tibby
    9 Oct 2005
    Can't see it in the admin tools>local manager.
    I still get this weird thing on boot up saying like "No BIOS detected".
    I think nothing of it, as my pc boots and I can access BIOS settings.
  7. DougEdey
    5 Jul 2005
    This is a common misunderstanding by owners of motherboards with SATA raid.
    SATA RAID requires a new BIOS to be loaded when drives are found to maintain then, if it doesn;t find a hard drive at all on its ports it will say "No BIOS detected"/"BIOS not installed" or similar, check which ports you're installing it in.
    Goto My computer -> properties and check that all the hardware is correctly installed.
  8. Tibby
    9 Oct 2005
    I installed it on a normal SATA port, not a RAID port.
    It came up with the BIOS message even when I was just using an IDE HDD.
  9. BUFF
    BUFF What's a Dremel?
    25 Mar 2005
    perhaps it would help if you said what mobo you are trying to install on?
  10. Tibby
    9 Oct 2005
    Asus A8V.
  11. BUFF
    25 Mar 2005
    VIA 8237 southbridge?
    You need to jumper the drive for SATA150 compatability see here
