Installing Vista with 4GB Ram
Discussion in 'Tech Support' started by warlord2000ad, 20 Dec 2007.
  1. warlord2000ad
    warlord2000ad The 20 Year Old Guy
    18 Dec 2007
    Ill be installing Vista 64 on my new PC early next year.
    I've heard in some places that you should install 2GB of RAM, then install Vista. Then add in the extra 2GB of RAM to make it 4GB after the install has finished. Is this true, if so, why? I know windows has never been great at memory management but this does sound a little strange.
  2. OleJ
    OleJ Me!
    1 Jul 2007
    Straight off the top of my head:
    Vista 64 should have no problems. Vista 32 seems silly if you're wanting to use your 4GB RAM. The 32bit Vista will only let you use 3GB RAM.
    Someone please correct me if I'm wrong.
    Edit: Was a bit tired there. Didn't spot you had already written it was Vista 64 :duh:
  3. blu
    blu What's a Dremel?
    22 Oct 2007
    i installed vista x64 with 4gb of ram no problem
  4. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    2 machines I built with 4gb and vista 64bit both intalled perfectly.
  5. jkeyser14
    jkeyser14 What's a Dremel?
    26 Mar 2006
    You can install it with 4GB no problem in 64. The more memory you have, the more it will use. It doesn't matter when you add it, it checks every startup. Right now Vista is using 1.3 gb ram out of my 4gb.
  6. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    My mate had the problem you describe (with the 64-bit version), but its simple enough to get around - just install 2Gb and then install the other 2Gb after installation. You may also have to apply a hotfix.
  7. Drachnem
    Drachnem Minimodder
    15 Nov 2003
    My boss at work said they came up with a hotfix to allow vista 32-bit to use all 4 gigs of ram, I haven't heard anything about it. Anyone here heard?
  8. jkeyser14
    26 Mar 2006
    Not true. They released in SP1 Beta (and it will be in SP1 when it's official) a patch that shows the bios memory. So if you have 4 sticks in your computer, it will show that, but windows still won't use it.
  9. OleJ
    OleJ Me!
    1 Jul 2007
    LOL that's awesome :)
    I can already imagine noobs showing of their 8GB Vista32 rigs :D hahaha
    Goooooo Microsoft!
  10. warlord2000ad
    18 Dec 2007
    So generally 64bit is fine, but 32 may have issues. I'm going 64bit anyway :) Cheers
  11. BUFF
    BUFF What's a Dremel?
    25 Mar 2005
  12. Major
    Major Guest
    My mate did it with no problems I think...
    Also, can someone answer this please... (Sorry to go off topic) - IS 4GB on Vista better in games than XP using 2GB?
  13. oasked
    24 Aug 2005
    Depends on the game, and whether its DX10 or not. Generally, Vista is a little slower in DX9, but not by much.
  14. J_Harrison89067
    J_Harrison89067 .
    22 Dec 2007
    Ive got 4GB of RAM and 32bit OS's atm (Im dual-booting XP Professional and Vista Ultimate), over the Christmas period Im gonna change to x64 for both though, thanks for the answers. :)
  15. talladega
    talladega I'm Squidward
    18 Aug 2007
    what about with 8gb on 64bit? has there been any problems with that? because i can get 8gb of ddr800 for $250 or less so i may as well get it as i do video processing. but will there be a difference between 4gb and 8gb?
  16. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Vista 64 ultimate can handle up to 128GB RAM, so there shouldn't be any problem. Home premium is max 16GB while Home basic is max 8GB.
    The difference will be, well.. 4GB. I don't think you will notice much performance difference before you pass the 4GB mark in usage. When this will happen depends on what you are working with.
  17. talladega
    18 Aug 2007
    well i love having lots of programs opened at the same time. :D
