A/V Integrating an old stereo amplifier
Discussion in 'Hardware' started by sreyno21, 7 Nov 2012.
  1. sreyno21
    sreyno21 What's a Dremel?
    7 Nov 2012
    Hi! New here! I'm building my first rig. I'm really excited and wanted to know if anyone can tell me what I can do with my stereo. Its a pioneer sa-950. I hook my laptop to it with aux running to the component ports. That's the only connection I have on the stereo, jus component. If it matters, here are some numeros: 190 watt 120 volt 60 hz.
    Is there a better connection I can get running from the computer than aux?
    Are there any sound cards which may work better with my old ass system than a stock sound card?
    I really appreciate any advice! :D
  2. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    For a laptop by itself, use a line out to connect to an external amplifier. Usually you can configure the headphone port to work as a line out (i.e. turn off the gain).
    If you're building a desktop PC there are a number of Asus cards (Xonar) which are great value. Same principle here; use the line out into another amp and let it do all the work.
  3. asura
    asura jack of all trades
    22 Apr 2009
    Or a step up would be a discrete USB DAC - something like the ObjectiveDAC - which goes PC->USB->DAC->RCA->Amp.
  4. MSHunter
    MSHunter Minimodder
    24 Apr 2009
  5. sreyno21
    7 Nov 2012
    Much appreciated!
