News Intel Core i3 Clarkdale details leaked
Discussion in 'Article Discussion' started by CardJoe, 24 Nov 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. dolphin-promotions
    dolphin-promotions What's a Dremel?
    12 May 2009
    I keep delaying building a HTPC and I am now thinking it maybe worth holding out to see what these bring to the table. 103 euros seems like a decent price for the lowest end one.
    Though I guess GPU performance will be the deciding factor.
  3. smc8788
    smc8788 Multimodder
    23 Apr 2009
    I assume all of these are dual cores? Any idea if/when there will be any more quad core i5's?
  4. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    Doh!
    These parts will be a bit too late for the PC I'm building later this months. Shame.
  5. crazyceo
    crazyceo What's a Dremel?
    24 Apr 2009
    This does look interesting. The thing going for AMD is the lack of new motherboard, ram needed for the upgrade.
    However, if you are buying a new system it's looking like Intel for any build regardless of price.
    Looks like Intel will recoup that money given to AMD a couple of weeks ago quite easily. What AMD are going to do I don't know, the only thing going for them at the moment is ATi but will that change as well early next year?
  6. AshT
    AshT Custom User Title
    9 Jul 2009
    Whats the difference between Level 1, 2 and 3 cached memory? I've never questioned it when it was just L1 and L2, but now L3 is in the tech specs I gotta know.
  7. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    Please inform me better if i've missed the point (and i'm sure I have), but why do I want a CPU with intergrated GPU? Wouldn't upgrading gfx when needed, also mean replacing a CPU which is otherwise perfectly adequate. Or ending up buying a dedicated gfx card anyway. Is this just aimed at small HTPCs?
  8. Ryun
    Ryun What's a Dremel?
    28 Apr 2009
    I feel like these chips are only going to be successful on paper and in reviews but not in sales, and in no way a nail in the coffin for AMD. OEMs are still trying to sell off their inventory of Core 2's as well as their inventory of Socket LGA775 mobos. Intel will be very much competing with itself before there's a huge threat to AMD.
    Now, if zambezi and llano are flops in 2011, then AMD is going to have a problem.
  9. Guest-16
    Guest-16 Guest
    Because it means cheaper motherboards, less cooling issues because it only needs one large heatsink and OEMs love onboard graphics. Intel is the biggest graphics manufacturer in the world, thanks to its shitty IGPs.
    You can buy one of these and plug in a graphics card like any normal motherboard and it disables the onboard.
    L1 cache is tiny and is the fastest most needy place on the CPU pipeline. L2 cache is slightly bigger, slightly slower and holds more general data at the end of the pipeline. L3 cache is the slowest and holds more complete, but regularly accessed data from all cores, not just one. It stops other cores sniffing each other to see what they are doing: it's called a snoop-filter. Dual cores don't really need a L3 cache, but many-core CPUs do.
  10. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    L1 is a tiny bit of on-chip superfast RAM (not really, i know) only one core has access to. L2 is somewhat bigger somewhat less fast RAM on the chip where both cores have acces to. and L3 is again bigger and again somewhat slower and buffers between the RAM (the sticks in your MB, not on-chip) and the L2, like the RAM buffers between the hard disk and the CPU.
    somebody more hardware litterate: correct me if i'm wrong
    EDIT: ah, ninja'd by bindi
  11. SMIFFYDUDE
    22 Apr 2009
    Thankyou Bindi
  12. TSR2
    TSR2 What's a Dremel?
    19 Aug 2009
    Those are some pretty decent numbers, although I assume the GPU will be more or less useless for anything worth doing? I'm still not sold on the idea of a GPU in the same package as the CPU, as it can't be especially good to keep the heat down, which outweighs the advantages of bandwidth.
  13. Guest-16
    Guest-16 Guest
    :thumb: no probs!
  14. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    The lowest i3 is still to expensive... All I need is a cheap dual-core, a mobo, 4gb ram DDR and a GPU that has a HDMI connector.
    For example:
    AMD X2 250 (2 core, maybe 3 core) -> 50€ (no need for more, the HD movies are played thru the onboard GPU), fresh cpu...
    Asus M4A785TD-V EVO -> 75€ (with HD4200, plays some games, and offloads the cpu with the HD acceleration for blu ray's)
    4Gb DDR3 -> 65€
    Board + AMD cpu = 125€
    - The lowest core i3 -> 103€.... without a mobo, the cheapest 1156 mobo I found was 110€, but the new i3 mobos come without a NB, just a SB, but even without the Northbridge I don't believe it will get as down as the 75€ AMD motherboard... Still too expensive for HTPC...
  15. AshT
    9 Jul 2009
    Thanks Bindi & alpaca
  16. tad2008
    tad2008 What's a Dremel?
    6 Nov 2008
    The concept has been an interesting one ever since it first surfaced, which seems like far too long ago now.
    AMD in trouble? Personally, I don't think so, Intel have never made any real progress in to the graphics market or given any of the real graphics card makers anything to worry about and this is no exception.
    Clearly this is a niche product that will have a greater appeal in smaller more portable devices where power saving and less demanding graphic uses apply.
  17. Tangster
    23 May 2009
    I'd like to see if VIA Nano could compete with i3 if it went dual-core. Imo, a dual-core nano with an onboard ATi 5-series GPU would be cool.
  18. Guest-2867
    Guest-2867 Guest
    turbo? seriously? not had turbo for about 15 years lol
  19. Star*Dagger
    Star*Dagger What's a Dremel?
    30 Nov 2007
    AMD/ATI is ruling on the GPU side, if they get (when?) on top again on the CPU side, watch out!
    I would still like to see at least 3 more companies making X86 procs.
    Not a fanboy, I just buy the best,
    Star¤Dagger
  20. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    The whole idea intrigues me, some people aren't bothered about GPU performance and games. am sure this chip will be sold in alot of OEM systems were people just want a computer in the house, and at least when you get a motherboard with onboard GPU, you now get some choice in the GPU to go with that board.
    Personally not for me but prefer to have seperate but we'll see how the future pans out on these
Tags: Add Tags
