Hardware Intel Core i7-3770K CPU Review
Discussion in 'Article Discussion' started by brumgrunt, 23 Apr 2012.
  1. Baz
    Baz I work for Corsair
    13 Jan 2005
    Word-mo-trons suffered catastrophic break downs yesterday. Should be up and running again shortly.
  2. User-sam
    User-sam "Rare!"
    10 Apr 2010
    Any update on the I5 3570K review ?
    Cheers!
  3. Shirty
    18 Apr 1982
    Harry I'm going to cry if that 3570K review doesn't appear soon!
    Don't drive me to your competitors, I like it here. :grr:
  4. dark_avenger
    dark_avenger Well-Known Member
    9 Jul 2008
    Another i7 920 here, nothing I've thrown at it hasn't been quick enough.
    Running 3.8Ghz but stable at 4.53Ghz if I really need the grunt.
    Time to get a faster SSD and wait for haswel-e I reakon...
  5. Woollster00
    Woollster00 New Member
    24 Aug 2010
    Not much improvement to warrant an upgrade on my 960 was expecting a little more probably upgrade in 2 years
  6. spt
    spt New Member
    19 May 2009
    Am getting a little worried here. Today we have an article about facebook photo etiquette (really>?!?!?!) but still nothing about the 3570K
  7. Shirty
    18 Apr 1982
    :sigh:
    I'm a bit sad, something's not going quite right here.
  8. Dewi
    Dewi New Member
    10 Jan 2011
    I think, looking at the tables from the 3770K review that we know what we need to know about the i5 chips.
    The actual thing I'm holding out for, and what I really really (wishing upon the morning star sort of thing) hoping for is that the delay is because they are testing some z77 motherboards with the IvyBridge chips.
    That would be fantastic for those of us upgrading come Monday!
  9. Guest-16
    Guest-16 Guest
    You realise that in future I will now flood you inbox with ASUS pictures!
  10. MrGumby
    MrGumby CPC 464 User
    27 Apr 2009
    Really hoping for a review of the 3570k. Would like to see a few benchies comparing them at the same clocks.
    Had a play with a 3770k today and 4.6Ghz was stable.
  11. Jo3y
    Jo3y New Member
    28 Apr 2012
    I joined up just to say how poor this review is, no temp section and quoting '4.8ghz easily achievable on air' when reviews all over the net are showing POOR OCing temps in excess of 80ºc at anything 1.3v or higher.
    Go read Tweaktown if you want some real information.
  12. Jo3y
    Jo3y New Member
    28 Apr 2012
  13. MrGumby
    27 Apr 2009
    From the play i had at scan with a 3770k msi z77GD65 and a drak rock pro cooler. I managed 4.6Ghz stable with a vcore around 1.285v. Got to say i much prefer the asus uefi. Temps did start to rocket.
    But ive got to say IB aint as bad as some doom mongers are saying. Im sure with a bit more time to tweak things 4.8Ghz may have been possible.
  14. Agrobacterium
    Agrobacterium New Member
    12 Mar 2011
    I've been browsing around info about Ivy Bridge, and I see high temp of Ivy bridge being discussed often in bit-tech and CPC mag. Peculiarly I don't see any discussion regarding the thermal compound between the core and the heat spreader, something which is hotly discussed in Japan.There's a difference between Sandy and Ivy, the former has direct soldered contact while the latter has generic white compound.
    http://pc.watch.impress.co.jp/docs/column/sebuncha/20120511_532119.html
    The max temp fell by 20C just by changing the thermal compound, and frankly it's almost as dramatic as a stepping revision. To crack open the heat spreader is by no means recommendable for everyone, but perhaps CPC/bit-tech can do a thermal test where finally Sandy and Ivy are finally compared fair and square, as well as how-to section for opening the heat-speader.
  15. [USRF]Obiwan
    [USRF]Obiwan New Member
    9 Apr 2003
    I watched a podcast last night from PC-Perspective discusing the heatspreader thermal compound issue. They where talking about some other overclockers website that tested this and could not see any diference in using different compount. The guys from PCPer concluded that the Ivy Bridge is just hotter then Sandy Bridge.
    here:
    http://www.overclock.net/t/1258439/ivy-bridge-3770k-heat-spreader-thermal-grease-testing
    and here:
    http://translate.google.nl/translat...bridge-vervangen-heeft-nauwelijks-nut&act=url
    And here:
    http://www.xtremesystems.org/forums...-3770K-intel-TIM-AS5-MX4-PK1-LQP-IX&p=5104115
    So I really do not know what to believe anymore.
  16. sandys
    sandys Well-Known Member
    26 Mar 2006
    It will drop 10-20 degC off of a high volt overclock which is enough depending on your cooling to stop the thermal throttle happening on extended durations of high load.
Tags: Add Tags
