Hardware Intel Core i7-7700K Performance and Overclocking Preview
Discussion in 'Article Discussion' started by Dogbert666, 5 Dec 2016.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. Spigsy
    Spigsy What's a Dremel?
    28 Sep 2009
    So it looks like a clock speed increase of ~7% offering ~8-9% performance increase in most benchmarks.
    It's great to see a return to 5ghz overclock territory (if, as you mention, this is a representative sample) but there's little else to get excited about in this release.
  3. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    And... we are back at the "Prehot" era...
  4. Combatus
    16 Feb 2009
    I have to say that I too want to see Intel push this more. Broadwell was actually a great 1080 gaming CPU and had vastly superior performance compared to AMD's APUs outside of games too. If Intel had knocked back the CPU grunt a bit more to hit a better price point (and actually shipped samples to journalists) it would have gone down a storm.
  5. play_boy_2000
    play_boy_2000 ^It was funny when I was 12
    25 Mar 2004
    There's an extra power consumption chart on page four where the photo editing chart should be and a small typo in the conclusion.
  6. Guest-56605
    Guest-56605 Guest
    I can't say as I'm overwhelmed any by it's performance Antony, I have a 5.2GHz capable 6600k which holds a day to day overclock of 4.6GHz at well below stock voltage - would I be correct in saying the Z270 motherboards are backwards compatible for Skylake CPU's?
  7. maverik-sg1
    maverik-sg1 Minimodder
    18 Aug 2010
    I wanted to see how my 2500K at 4.8ghz compared in Terragen, how do I get it run the same benchmark that your guys use?
  8. rollo
    rollo Modder
    16 May 2008
    The voltage going through the chip is surely not long term stable. Which was always the goal of overclocking. Gain performance don't kill chip.
  9. Combatus
    16 Feb 2009
    They will be indeed and vice versa. We had limited time to play with the sample but in the full review we'll be trying out maximum overclocks at certain voltages - we went for broke here and got to 5.1GHz using a standard liquid cooler and 1.44V. We'll also see what's possible at stock voltage.
    That's going to be a massive hike up from what would be required for stability at 5GHZ and 4.9GHz as the voltage curve is usually exponential once you get to a certain point. With a turbo boost single core frequency of 4.5GHz, I'd imagine 4.6GHz or maybe even 4.7GHz could be achieved at or below stock volts too. We shall see :)
  10. Combatus
    16 Feb 2009
    You can download the file here https://www.dropbox.com/s/cz76x2cjr2j64bd/benchmark 52.tgd?dl=0
    Grab Terragen 3 from here https://www.dropbox.com/s/jettck2rquz1spg/Terragen3-Win64-30100.msi?dl=0 That's the version we used - There are different versions of v3 out there and they just released 4 too, so make sure you use this one so the results are comparable.
    File>open (project file)
    Click on the renderers tab
    Select full render at the top left then render image half way down. It will record the time taken for you.
  11. Combatus
    16 Feb 2009
    Not it's not long term stable, we never said it was. This was purely an exercise to find the maximum stable overclock using traditional cooling. As I mentioned to 23RO_UK, we'll be doing a full review with detailed overclocking to see what's possible at stock volts and a reasonable every day voltage. :)
  12. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    Looking forwards to the full review. My i5 2500K is still going strong and I see no reason to upgrade my 2011 computer.
  13. rectro
    rectro What's a Dremel?
    17 Jul 2004
    I'm supriced by the low cinebench score's. My 5930k at 4.5 ghz gets 1278 points. Need to see a 6 or 8 core to see any being it unless this chip is way cheaper than a second hand 5930k.
  14. maverik-sg1
    18 Aug 2010
    My 4.8ghz 2500K ran the terragen benchmark in 320s in a far from optimised machine Vs 309s for the 7700 @ 5.1ghz.....not that impressive, power consumption is considerably lower though.
    I was expecting more, lots more given we're now several generations passed Sandy Bridge and comparing 32nm Vs 14nm process technology.... Is my GPU assisting with the rendering?
    If I recall Cinebench will also run faster due to the HT on the 7700, so no real comparison to be had there
  15. zimano
    zimano What's a Dremel?
    1 May 2014
    From the point of view of your wallet, this is a good thing :) I've got the same CPU. I'd usually spend about £150 on a new one every three years, might be tempted to spend a lot more on one now it seems to take 6 years+ to get something worth upgrading to. Who knows, we might be here in four years time complaining that there's only been a cumulative IPC speed increase of 50% over 10 years lol
  16. raybies
    raybies What's a Dremel?
    4 Aug 2009
    Mine easily goes to 4.9Ghz @ 1.35v ~80c and I thought that was awesome. I've been a little apprehensive about pushing it further, are you just playing with voltage and multiplier? My Asus Pro Gamer has sooooooo many darn options, but I've limited myself to LLC + voltage + X.
    Which mobo you using?
    I'm interest in your 4.6Ghz below stock volts settings.
  17. raybies
    4 Aug 2009
    Personally I would have done a 6700k Mhz for 7700k Mhz comparison (both @ 4.5Ghz), to accurately ascertain real improvement.
Tags: Add Tags
