Hardware Intel Core i7 CPU and Platform Value
Discussion in 'Article Discussion' started by Guest-16, 11 Nov 2008.
  1. Guest-16
    Guest-16 Guest
  2. Teq
    Teq What's a Dremel?
    11 Aug 2008
    I would have liked to have seen the gaming averages in the conclusion completely separate from the 2d/synth stuff, I should imagine that to most people that frequent bit-tech that is where their priorities lay
  3. Yardstick
    Yardstick What's a Dremel?
    3 Dec 2004
    Agreed on separating out gaming from other 2d stuff. When I am gaming performance is everything. When I am decoding DVDs, zipping files etc it's usually running in the back ground and performance is not a major issue.
  4. Teq
    11 Aug 2008
    ...instead of just bitching I decided to do something about it and have very quickly created an average normalised gaming performance chart ( top down ), nice to see the Q6600 still near the top ;)
    ( 146.0 ) Core 2 Duo E8400 OC (2x4.0GHz, 1,760MHz FSB, DDR2)
    ( 138.3 ) Core 2 Quad Q6600 OC (4x3.6GHz, 1,600MHz FSB, DDR2)
    ( 134.6 ) AMD Phenom X4 9850 OC (4x3GHz, 2.0GHz HTT)
    ( 134.1 ) Core 2 Duo E8400 OC (2x4.0GHz, 1,760MHz FSB, DDR3)
    ( 131.8 ) Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR2)
    ( 125.2 ) Core 2 Quad Q6600 OC (4x3.6GHz, 1,600MHz FSB, DDR3)
    ( 123.8 ) AMD Phenom X4 9950 BE (4x2.6GHz, 2.0GHz HTT)
    ( 123.3 ) AMD Phenom X4 9750 (4x2.4GHz, 1.8GHz HTT)
    ( 121.7 ) AMD Phenom X4 9850 BE (4x2.5GHz, 2.0GHz HTT)
    ( 118.9 ) Core 2 Duo E8500 (2x3.16GHz, 1,333MHz FSB, DDR3)
    ( 103.8 ) Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR2)
    ( 101.8 ) Core i7 920 OC (4x4GHz, 1,600MHz DDR3, 3.6GHz QPI)
    ( 96.3 ) Core i7 920 (4x2.66GHz, 4.8GHz QPI, SMT enabled)
    ( 96.3 ) Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR2)
    ( 95.4 ) Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR2)
    ( 90.0 ) Core 2 Quad Q9550 (4x2.83GHz, 1,333MHz FSB, DDR3)
    ( 88.1 ) Core 2 Quad Q9450 (4x2.66GHz, 1,333MHz FSB, DDR3)
    ( 84.9 ) Core 2 Quad Q6700 (4x2.66GHz, 1,066MHz FSB, DDR3)
    ( 71.5 ) Core i7 940 (4x2.93GHz, 4.8GHz QPI, SMT enabled)
    ( 58.2 ) Core i7 965 (4x3.2GHz, 6.4GHz QPI, SMT enabled)
    ( 57.4 ) Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR2)
    ( 56.1 ) Core 2 Quad Q9650 (4x3.0GHz, 1,333MHz FSB, DDR3)
    ( 55.1 ) Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR2)
    ( 51.0 ) Core 2 Extreme QX9770 (4x3.2GHz, 1,600MHz FSB, DDR3)
  5. sandys
    sandys Multimodder
    26 Mar 2006
    Nice round up, pretty much came to the conclusion that the X4 was best buy for me on price when I upgraded despite not necessarily being a headline performer, especially as I had and SLI graphics setup, once thats factored in the Intel platform is mucho expensive.
    In those benchmarks whilst you've included OC'ed results it seems to me at least that you may have not got the best performance out of the X4, for example you can up the NB speed as well as HTT and it appears you've done neither the jump in NB speed and HTT from 1.8/2Ghz to 2.2/2.4/2.6Ghz (depending on what you get) is quite beneficial, seems you've only upped the multiplier for clock speed though giving no additional cache memory bandwidth to the AMD platform so it could perform even better than it does in these charts whereas the Intel OCs do get that bump.
    OK the increase is probably little more that a few % from the benchies I did when OC'ing but if you're going to include Oc'ed results from each platform at least exploit all the easy stuff, I'm running on a Nvidia chipset with x64 which is supposedly poor for Oc'ing and have no problems cranking these things up.
  6. Er-El
    Er-El Minimodder
    31 May 2008
    Looks like the Q6600 is the biggest value quad core CPU out there after all.:clap:
  7. Tim S
    Tim S OG
    8 Nov 2001
    for gaming the CPU makes little-to-no difference once you are playing games at GPU limited settings. That's not to say you can't get away with a rubbish CPU and a flagship graphics card, but if you're a gamer, a q6600 at stock is generally plenty of performance. There's no difference in peed between an e8400 and an i7 920 in most games. That's why I'd be against separate gaming scores.
    Modern games are, for the most part, NOT CPU-limited unless you play at 640x480 or without AA/AF
  8. Teq
    11 Aug 2008
    If there is no difference between CPUs when benchmarking games - why do they even appear in a value roundup? For the most part I agree with you Tim, but separation for gamers will at least show those of us who are uninterested in basic platform performance that there is little reason to upgrade from what we are currently using...
  9. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    I don't think you really can tell by this comparison. Don't you think, 3.6Ghz on a Q6600 is a bit over the top guys? I certainly wouldn't push my CPU this far, because it might be possible but probably not ideal for extensive daily use for a few years? :rolleyes:
  10. Guest-16
    Guest-16 Guest
    I had someone complaining 3.6GHz was too slow and he ran his at 4Gs all day. Others thought 3.2 is too slow.. I just found the stable maximum for our CPU - you can never make a set of results to suit everyone, after all, we used X48 instead of P45... etcetc
    If my 2.4 did 3.6, I'd run it at 3.6. If it died, by that time I'd upgrade.
    Because there is some difference, and we set out to ascertain the BS or non-BS about "of our new engine is multithreaded" - in which case, the Core i7s would be loving them. Crysis was apparently "made for quad cores" remember, yet the E8400 loves it.
    Also, Teq, the people above you are complaining they ONLY want to see gaming benchmarks. Soooo... we try to build a platform for everyone.
  11. djDEATH
    djDEATH Habari gani?
    23 Mar 2006
    this is very encouraging, what it means is that although my AMD machine is never gonna be at the top of the benchmarks, it shows that it still holds very strong value for money, and that a comparable Intel machine WOULD cost me more.
    I like it, and i have decided against my initial decisions too get meself a 9850 BE X4. Nice
  12. barrkel
    barrkel What's a Dremel?
    31 Jan 2007
    IMO you should have plotted a scatter-graph of price-performance when doing these comparisons, rather than percentage-based bar-charts.
    The thing about price/performance tradeoff is that different people are willing to make different compromises, particularly when they can see something better that's close in price. However, your percentage-based charts hide this fact, as something slow and very cheap will appear to be similar to something expensive and very fast.
    Price/performance scatter graphs are easily read using a line of negative slope (i.e. like \). The slope (steepness) depends on personal preference (i.e. willingness to pay for performance). The line is slid out right as far as possible until the last point is on the line. This is then the optimal price/performance value for your preference.
    The crucial advantage is that points close to the selected point are clearly visible and, because the graph hasn't lost information, the exact tradeoff - more or less absolute performance with less or more value for money - is simultaneously visible.
    Guest-16 likes this.
  13. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    Q6600 is about as close as we can get to the old value for money performance that the AMD Athlon 2500+ Barton offered, i had both types of barton, the XP-M was a beast and out perfromed my friends brand new Athlon 3400+ SKT 754, ah those were the days!
    Love my Quad, cant see upgrading it for a while yet, but every now and then i want to change it. Its the upgrade bug!
  14. fathazza
    fathazza Freed on Probation
    20 May 2002
    I think we need our English hats too:lol:
    interesting article :)
  15. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    I'd say with the new Denebs coming 9850BE + AM2+ >= Q6600 S775.
    3.0GHz on a Phenom 9850 is fairly commonplace.
  16. Guest-16
    Guest-16 Guest
    those hats
    that hat
    our hats
    OR - you could wear multiple math hats for SLI or Hyperthreading hatting action
  17. Skill3d
    Skill3d Minimodder
    29 Sep 2005
    is that a hattrick?
    /ot guess ill buy the q6600.... except if I win the lottery offcourse
  18. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Interesting to note that the Q6600 has gone up in price AGAIN! Its also out of stock by the looks of it on eBuyer.
  19. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    interesting article. I too put in my vote for a scatter plot graph.
    I think this graphs over represents the 920 system as while the chip itself is fairly priced the mobo's are insane as well as memory, and it sounds like it will be awhile to come before we see <$200 mobos for the core i7
    I've been doing the math and while I like the core i7 and the performance I think you can get beef up a system in many other ways if you include the extra cost of the mobo and RAM
  20. Guest-16
    Guest-16 Guest
    Nice idea! While impossible to do in our graphing engine I could screenshot Excel (like I do in PSU reviews).
    So you're saying you have relative performance (or, absolute?) on the X axis, then price on the Y?
    Hahaha :D
