Reviews Intel Core i9-10900X Review
Discussion in 'Article Discussion' started by bit-tech, 23 Jan 2020.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. sandys
    sandys Multimodder
    26 Mar 2006
    What do you mean close, 2920x is half!!! the price of this CPU, so it makes a case for itself on that alone as you can get an x399 board and 2920x chip for the price of the 10900x and have a better featured board not requiring VROC etc.
  3. Vault-Tec
    30 Aug 2015
    Looking at the CB R20 scores on multi threading it's basically identical to my 1920x. Both stock and overclocked.
    And you're right Sandys, you can do much better at that price. My chip and board cost me £490. Less than this chip.
  4. sandys
    sandys Multimodder
    26 Mar 2006
    It is also worth stating that price difference between x299 and x399 motherboards is next to bugger all, the cheap x299 boards can only take 4 core chips, nothing more, ones you can possibly use with the chip if there is compatibility start at ~235 about £15 less than an x399 starts.
    Yup the CB20 for my x2920 puts it on par at least, similar to the x2920 in the article, the 12 core Intel chip will be interesting to see though, I was considering it on the assumption that being an Intel chip I could 'clock it to 5Ghz and have better gaming performance, sounds like they are not having that sort of luck and I probably made the right choice sticking with x399 for now.
    Well actually the right choice would have been to do nothing and wait for the next step of options from Intel/AMD as the 2920x is such a meagre update over my gen1 but it was only £350 quid.
    The temptation to splurge on TR3xxx is still strong, if AMD release a cheaper chip I would cave.
  5. monty-pup
    monty-pup Minimodder
    8 Apr 2018
    Can we get the ‘higher is better’ and ‘lower is better’ added to the charts please. It works as a quick and easy reference when checking the chart data.
  6. Vault-Tec
    30 Aug 2015
    £220 cheapest board I could find. Asus Tuff X299 mark 2.
    However yes it's £40 less than the X399 Aorus Pro and Asrock Fatal1ty but it also has waaaay less slots and features. Probably due to Intel's lack of lanes.
    Most of the reason I upgraded my Broadwell E Xeon was for storage. The NVME part is awesome.
    I also don't like that there are cheap X299 boards that don't support the higher end CPUs. That's seriously lame. This stuff is confusing enough ffs.
  7. Vault-Tec
    30 Aug 2015
    It's almost impossible because X299 is totally different. You'll get less, though. Problem is the Aorus I looked at that looked similar to mine can't run anything above 4 cores.
    I would ask "what were Intel thinking?" But it's obvious. Greed and a determination to sell 4 core CPUs for maximum coin.
    Looking back just makes it all look so much worse.
    Edit. Jesus. £690?!?!? I thought it was like £500.
    £690 is exactly what you can buy a 1920x, X399 Aorus Pro and 32gb of Corsair dom plat RGB 3200.
    I think they need to cut those prices more. Much more. Like, in half.
  8. Vault-Tec
    30 Aug 2015
    It's not so much chipsets but features. How many NVME slots? Board layout? Features like usb, usb c etc.
    And ultimately, lanes. As that is what it's becoming now. Cores are no longer the sticking point, you can literally buy as many as you want now.
  9. SuperHans123
    SuperHans123 Multimodder
    27 Dec 2013
    Seriously, why are they bothering
  10. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    X299 is still the only game in town if you want ITX HEDT. Even the barmy lads over at ASRock couldn't figure out how to cram the Threadripper socket and breakouts onto an ITX board (and they somehow did it with LGA3647 and 6 channel memory, so if it were possible they would have done so).
    Hands up anyone actually using more than the 48x CPU lanes provided by Cascade Lake-X? That's dual x16 lane GPUs plus quad x4 lane nVME SSDs, without even touching the chipset lanes (where you'd usually hand network controllers and drive controllers to take advantage of CPU offloaded DMA).
  11. sandys
    sandys Multimodder
    26 Mar 2006
    Why would you even want and ITX HEDT board, the power requirements will require some serious cooling and you wouldn't have any slots to take advantage of the main benefit of HEDT platform, ultra niche.
  12. edzieba
    14 Jan 2009
    quad-channel memory, x16 slot with bifurcation, and 3x x4 m.2 slots With flex risers you could have 2x x8 lane slots and 3x x4 lane slots if you wanted (I've seen a build for a virtual networking testbed drawing out multiple 10GbE NIC cards from an ITX board). Cooling is not an issue with proper cooling choice (e.g. even as small as the Dan A4 there's 92mm AIOs like the Asetek 545lc, and even a 'large' ITX case like the Ncase M1 can fit dual 240mm rads), as is power with current SFX PSUs (though I've seen at least one x299 build in the NFC S4 Mini, so you can do it with external power too).
    99% of desktop cases are massively oversized for actual usage.
    David likes this.
  13. sandys
    sandys Multimodder
    26 Mar 2006
    pointless, just get a better board and case if you are breaking out pci to use slots and adding external power etc surely ITX is wrong and you are just constraining the system for zero benefits, each to their own I guess.
  14. Vault-Tec
    30 Aug 2015
    Whilst x299 itx is a fantastic novelty and achievement it's pretty much very silly.
    As said it flies in the face of the platform itself.
    I'm hoping to put more ssds into my rig now.
  15. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    What's the issue with having a laptop-style external power brick and flex PSU if it makes the box that sits on your desk that bit smaller and neater? Weird thing to criticise mITX builds for imho, and awesome cases like the S4 mini wouldn't be possible without it.
  16. Vault-Tec
    30 Aug 2015
    Just so it's out there. I'm not criticising ITX builds. At all. I think they're ace. I just think itx and HEDT don't go.
    Why would you any way with things like the 3900x and 3950x? I mean really.
    Edit actually you know what? Nail, head.
    There wouldn't even be a x299 itx board unless Intel couldn't put highly threaded chips into desktop mainstream boards.
    That's why it exists. Not because it's cool because Intel can't shrink.
  17. sandys
    sandys Multimodder
    26 Mar 2006
    I'm down with ITX, I have a small ITX NUC style build myself, but to go ITX and breakout all the slots etc, it's a nit silly, plus of course the CPU power requirements, I mean the PSU will have to be massive as the TDPs are not the mins and these mutilcore chips can use much more.
  18. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    That's not very lice ;)
    David, sandys and Guest-44638 like this.
  19. Anfield
    Anfield Multimodder
    15 Jan 2010
    Funny enough, recent stories indicate that Intel will soon start pushing for 12V only PSUs, if that takes off then PSUs will get smaller in general.
  20. Combatus
    16 Feb 2009
    Well it's not half here in the UK. Half would be no more than £350. In the last 24 hours the Amazon price has fallen from £599 (which I was referring to when I wrote this) to £418. Still nowhere near half, but more worryingly, both Scan and Overclockers list it as end of life and it's not in stock so it might not be a viable alternative anyway.
Tags: Add Tags
