News Intel details 10nm, 7nm, 5nm process roadmap
Discussion in 'Article Discussion' started by brumgrunt, 14 May 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. SpAceman
    SpAceman What's a Dremel?
    1 Nov 2010
    MOAR TRANSISTORS!
    Doesn't seem that long ago that I was getting excited for 45nm... 65nm seemed small enough already at that point.
  3. dunx
    dunx ITX is where it's at !
    1 Sep 2010
    Or just MOAR thermal issues ?
    dunx
  4. SpAceman
    1 Nov 2010
    Good point. Someone should tell Intel to stop following Moore's law. We don't want moar transistors.
    I would like to think alternative semiconductor designs will deal with any thermal problems. Surely that is what they would be working on?
  5. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    I beg to differ, we do want MOAR transistors, but we want them without needing LN2 to keep the CPU cool at stock speeds lol
    I'm guessing they're already thinking about how to deal with the thermal issues given the poor thermal properties of Ivy Bridge.
  6. mclean007
    mclean007 Officious Bystander
    22 May 2003
    Care to clarify that? Thanks to 22nm and Tri-Gate, Ivy Bridge CPUs have a lower TDP than their Sandy Bridge predecessors. Specifically, both the 3770K and the 3570K have a TDP of 77W, against 95W for the 2700K and 2500K. The IB processors also apparently perform at least as well if not better in every situation at both stock and OC settings, have a faster GPU, and OC better. Doesn't sound like poor thermal performance to me.
  7. wyx087
    wyx087 Multimodder
    15 Aug 2007
    it's called Heat Density.
    the CPU itself is great, performs well as you said. but the processor as a product is disappointing due to the poor thermal interface materials used between the die and the heatspreader. hence the "heat issue" mentioned.
    solution is to change manufacturing process by soldering the heatspreader onto the die. at least that should work for a few years until 7nm made the "heat issue" resurface.
  8. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    At this rate, Intel will need to work on their molecule-shrinking technology to keep Moore's law going.
  9. rollo
    rollo Modder
    16 May 2008
    both chips under stock settings stock cooler reach about a similar temparature
    once overclocked is the temp dif
    at 4.5ghz the temps are aproaching 100c on most poor air coolers really do need a decent chip + cooler to get a overclock going
  10. Fat Tony
    Fat Tony Minimodder
    3 Jul 2009
    Looking forward to the first picometer chips
  11. noizdaemon666
    15 Jun 2010
    As Wyx said to be honest. Just because they have a lower TDP doesn't mean they have better temperatures. As others have said OC temps are abysmal.
  12. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Why not do a 32core at lower speeds with more cache. I really do not care if the processor takes 5x5cm or 1x1cm of space. In idle mode let 31 cores sleep to save loads of energy.
  13. noizdaemon666
    15 Jun 2010
    Pointless processor is pointless, at least in a consumer environment. You're hard pressed to find software that utilises anything more than 4 cores, let alone 32. In a server environment though, it'd be a good move.
  14. dunx
    1 Sep 2010
    I'm no expert in processor design, but how about spacing the four/six cores out on a bigger chunk of silicon, and adding the system RAM to fill the spaces in between ?
    dunx
  15. noizdaemon666
    15 Jun 2010
    But then RAM wouldn't be upgradeable, at least not without removing the IHS.
  16. jon
    jon Chief Phrenologist
    26 Aug 2009
    I, for one, welcome our sub molecular overlords ...
  17. Jezcentral
    Jezcentral Minimodder
    7 Sep 2009
    When I see stuff like this, I begin to wonder if something DID crash at Roswell.
  18. mecblade
    mecblade 14 year old Technophile
    12 May 2010
    The main reason for the poor thermal properties is the use of TIM (as Wuyanxu has stated) rather than Fluxless solder. A japanese review site managed to get a 14-24 degree Celsius reduction in temperature by using Coolaboratory TIM.
    http://www.techpowerup.com/165882/TIM-is-Behind-Ivy-Bridge-Temperatures-After-All.html
  19. mattbailey
    mattbailey What's a Dremel?
    26 Dec 2009
    Something did! Officially a weather balloon!
  20. mclean007
    22 May 2003
    It isn't really heat density. Heat density is a measure of thermal output per unit area / volume (depending on context). The issue you are describing is more about thermal conductance.
    Anyway, nomenclature aside, I understand the point - IB chips get hotter than they would if the process was different - but the temperature in itself is pretty meaningless. What counts is how the chip performs, and (heat issue or no heat issue) IB chips are epic.
Tags: Add Tags
