Hardware Intel DZ87KL-75K Review - A Last Hurrah
Discussion in 'Article Discussion' started by Meanmotion, 21 Jun 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    What?? No score?
    Edit: nevermind, shame there isn't any stock.
  3. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Too bad they aren't doing motherboard anymore. I'm pretty affraid for the future of the thin-ITX form factor.
  4. Gtek
    Gtek Doesn't raise the bar; he IS the bar.
    10 Oct 2009
    Exactly my fear...
  5. Stanley Tweedle
    Stanley Tweedle NO VR NO PLAY
    3 Apr 2013
    Giant blue sloped roof heatsinks and it has a beeper speaker. I might buy. Then again I might not. No I won't buy although I think my mobo doesn't have a beeper speaker.
  6. Xir
    Xir Modder
    26 Apr 2006
    Why spend time testing a MoBo that's not on the market nor likely to ever be in significant numbers while you've not yet tested the ones that are?
  7. Combatus
    16 Feb 2009
    As we mentioned in the review, it came as part of the Haswell press kit from Intel, and as no other boards were available prior to the Haswell NDA earlier this month, we had to use it to test the new CPUs anyway. It was only a little more work to do a review, but it's more of a feature really seeing as the motherboard may not be available. We thought it was interesting enough to take a look at, but don't worry, we've got plenty of boards on the way!
  8. springbok82
    springbok82 What's a Dremel?
    14 Feb 2011
    I am eagerly awaiting a review of the Asus Maximus VI Gene! What you guys have to say about that board will have a significant effect on whether I move to Haswell (from i7 930/X58) or not. More mobo reviews pretty please! :)
  9. GuilleAcoustic
    26 Nov 2010
    Still on a Q6600. I do not feel like jumping to Haswell. Waiting for Kaveri or maybe an Haswell based NUC.
  10. Stanley Tweedle
    3 Apr 2013
    Wow. Q6600. I still remember when I bought mine from OCUK for £135. I could finally play UT3 online without any FPS drops. Clocked at 3.6ghz for everyday use. Got it to 3.9ghz briefly. Amazingly when it came to selling it 4 years ago I got £102 for it overnight on eBay.
  11. springbok82
    14 Feb 2011
    Two of my workmates have old Core 2's and were on a tight budget to upgrade. As their budget did not allow a jump to newer architecture, I recommended a Q6600, easily picked up for around £40-£50 on Ebay. That was around 6 months ago, they're still thanking me. Like it changed their lives or something! That said, they are StarCraft: HotS fanatics.
    They have some dough now but see no need to upgrade either as both are saving up for better graphics cards instead.
    I still have the utmost respect for the Q6600!
  12. eUphoria
    eUphoria What's a Dremel?
    9 Apr 2004
    Well, I'm writing this from my very elderly E8500 based setup! Keenly reading though as I'm on the cusp of a Haswell upgrade and deliberating my mobo choices
  13. Floyd
    Floyd Wire Twister
    4 Dec 2008
    I still have my Q6600 in my spare machine. Still one of my best buys! Right next to the 2500k
  14. Elton
    23 Jan 2009
    Q6600s are fantastic things.
  15. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    I think the last Intel branded board I bought was the 440BX for my Pentium 2 haha.
    They're either woefully expensive or woefully under specced. Still, it is a shame to see them pull out completely.
  16. Elton
    23 Jan 2009
    The fascinating thing about them after using quite a few in other builds are the amazingly rock solid stability on them. They are admittedly mediocre to bad overclockers and they may not have the world's most awesome features. But I will vouch for their amazing stability in their stock forms. Even though they had miserably boring BIOSes and an oddly sparse layout they were always reliable as a workhorse board.
  17. Siwini
    Siwini What is 4+no.5?
    14 Sep 2010
    mmm q6600, tasty.
  18. AlienwareAndy
    7 Dec 2009
    Yeah they are always built really well and made from good quality components :)
    Their 440BX board was just gorgeous.
  19. Xir
    Xir Modder
    26 Apr 2006
    I should have figured this.
    Thx for the quick informative reply :thumb:
  20. jon
    jon Chief Phrenologist
    26 Aug 2009
    +1 to that
    Used them on my old Pentium builds for customers (and at home). They just never failed. I moved back to Asus when the Intel chips started opening up to overclock again (remember the days when only AMD allowed you to OC? I mean,other than the original Celerons. :)
    Wouldn't mind seeing Intel keep the mobo market open. As the review quite rightly points out, having Intel lay the groundwork for some mobos allows the industry partners learn a bit and iron out the wrinkles in new chipsets. This, in turn, makes intel's own chips better placed for brand support throughout the market.
    This might not be Intel's brightest move ...
Tags: Add Tags
