News Intel goes low-power crazy at CES
Discussion in 'Article Discussion' started by Gareth Halfacree, 8 Jan 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    While they were on updating the ultrabook spec, Intel really should have added some thickness and weight requirements. Some so-called ultrabooks are actually really thick and heavy yet they meet the other requirements of the spec.
  3. greigaitken
    greigaitken Minimodder
    26 Aug 2009
    until laptop screens are also sub 10w then then it doesnt matter all that much.
  4. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    I want Haswell out pronto because that will mean the launch of the Lenoxo X240 - which I desperately want for my studies.
  5. Blackshark
    Blackshark What's a Dremel?
    13 Apr 2004
    LoL - you young uns! Lenovo X240 for your studies :) I remember when I wanted a P90 - (pentium) and managed to get buy it plus a rather nice 'triniton black' 15 inch sony monitor that (although) being 15inch weighed as much as the 23 inch giants at Uni (Southampton)
    Good luck in your studies and I hope you get it
  6. OcSurfe
    OcSurfe Uber Noob
    7 Aug 2012
    Low power will be the way most things will go,
    Reduce power usage, reduce my bills, reduce global warming, SAVE THE UNIVERSE!
    well done intel!
  7. Skiddywinks
    Skiddywinks Minimodder
    10 Aug 2008
    This. Iterative power consumption decreases are always good, but when the single most power draining component is the screen, which are only getting bigger (especially in smartphones) and higher resolution, then you are going to get to the point where even a 70% decrease in draw from the SoC isn't going to make a difference to the 95% total energy draw the screen already had.
  8. Gtek
    Gtek Doesn't raise the bar; he IS the bar.
    10 Oct 2009
    Haswell GT3 + thin ITX - my cheesecake recipe
  9. ssj12
    ssj12 Minimodder
    12 Sep 2007
    demand OLED screens then
