Hardware Intel HD 4000 Investigation
Discussion in 'Article Discussion' started by brumgrunt, 28 May 2012.
  1. misterd77
    misterd77 What's a Dremel?
    18 Apr 2011
    the a8 k chip is currently around £98 (due for a massive price drop when trinity hits), and the intel i5 3570k is £170, the amd gpu portion is about 15% faster than the intel chip, and has a few inbuilt technologies that intel cant match for legal reasons, also, I think AMD will wipe the floor with them when it comes to driver support, so to sum up, the intel chip is 70% more expensive, and 15% slower (gpu).......
  2. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Don't hold your breath, Intel's iGPU driver development and release management is pants.
  3. Merglet
    Merglet What's a Dremel?
    28 May 2012
    Um. How were the "roles reversed" from the first two tests? You said all throughout the article that the AMD chipset was better. Then for Diablo 3 that the roles were reversed and the AMD chipset was far better? Lost your train of thought? Good article except for that blunder tho.
  4. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I've got one of these running now, and I call shenanigans. Loaded up Guild Wars, a seven year old game, and it stuttered and lagged so bad that I couldn't play. Put in a simple HD 5770, just fine. Ping was OK (before I get a question about that) but 1920x1200 completely crippled it in an old MMO designed to run on almost anything. It honestly looked like the old Intel integrated that we had to disable DX9 for it to run.
    Only problem with the 5770 is it's not mine. I'll be getting a new GPU in a week or so, but I was just trying to hold out till then. But gaming capable this ain't.
  5. 2bdetermine
    2bdetermine What's a Dremel?
    2 Apr 2009
    There isn't anything to investigated about the Intel HD 4000. It's rubbish! Like every others IGP that came before only to torment/killing PC gaming. On the other hand AMD solution offers some hope and not trying to killed off PC gaming in the process.
  6. nuc13ar
    nuc13ar What's a Dremel?
    5 Jul 2010
    NO GTA IV/EFLC benchmark?!! BLAH
    In title. I wanted to know if the increased IPC of Ivy Bridge made enough of a difference over the Stars architecture that could catch hd 4000 up to 6550d @ 1024x768/1280x1024. I will have to wait for other websites to review this chip I guess :(
  7. Elton
    23 Jan 2009
    Well I think it's fair to say that it'd defintively a step up and not made for 1920x1200.
    That said, it's clear that tests done these days are more CPU limited for APUs. Note that if the game was run on the A10 it'd perform much more admirably at a higher resolution. I'd say this is still a step forward, I mean back then integrated was good for only powering the desktop if it was from intel.
    Now at least it can do something. Not to mention it renders most bottom barrel GPUs obselete. Surely that is something to be proud of? Admittedly though, Intel's GPUs are hardly amazing. That and the HD5770 although old is still about 2x faster than the GPU on the A8 and A10.
  8. Blademrk
    Blademrk Why so serious?
    21 Nov 2003
    the "roles reversed" comment was in regards to the older intel chipset which came off better than the newer intel chipset in the Diablo 3 test and had nothing to do with the performance of the AMD chipset.
  9. PCBuilderSven
    PCBuilderSven Minimodder
    3 Oct 2010
    Desktop trinity chips will only make this lead bigger, AMDs mobile A10 APU's graphics is signifcantly faster than mobile IB's graphics.
  10. kent thomsen
    kent thomsen What's a Dremel?
    9 Jul 2011
    When you use your computer for audio production like I do, it's a problem, that the GPU (HD4770) doesn't recognize the audio sequencing software as a 3D job. Which is fair, it isnt. As a result it will stay at 250 MHz on the core and never scale up to750 MHz, full speed.
    And since the recording software is more demanding on the GPU than you might think, with VU-meters or plug-ins like reverbs and compressors pulsing away, it can get very glitchy. Especially when you zoom in or out on multiple tracks at a time.
    It will play CoD on 1680x1050 with everything to max without a hassle, though, because it will scale up, because the game is seen as 3D.
    Is there a similar scaling going on inside the HD 4000? Or is it running all it can all the time?
    Because if it doesn't scale down, it would be fine for my purposes.
  11. Deders
    Deders Modder
    14 Nov 2010
    Slightly off topic but is there an option to turn power saving features like this off in the Catalyst Control Center, or even windows power options?
  12. Elton
    23 Jan 2009
    Of course, just run CCC Overclocking at full blast all the time.
  13. kent thomsen
    9 Jul 2011
    @Deders; Elton:
    Sorry for being eager and off-topic.
    I'm afraid it isn't possible to make the GPU run full speed trough CCC OC. I can only adjust the 3D settings, i.e. over- or underclock the 3D frequency, not the 2D 250 MHz setting.
    That would create a lot of noise as wel.
    I'l thank for the replies and take my question to a more proper forum.
    Thank You.
  14. Elton
    23 Jan 2009
    Hmm, I wonder if you can adjust rivatuner to turn off the Voltage/Power Saving contols?
  15. Gradius
    Gradius IT Consultant
    3 Feb 2009
    Finally AMD is on the road again!
  16. Material
    Material Soco Amaretto Lime
    13 Apr 2010
    I only said that the roles were reversed for the HD 4000 and the AMD Radeon HD 6450, which they were.
  17. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    No you'd have to edit the vBIOS to crank up the speed of the lower profiles or to disable them entirely.
    Teelzebub likes this.
  18. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    interesting article.. don't really mess with the integrated gpu though- use a netbook with xp/linux and blinds to save power still.. I know someone who has a newer gaming laptop, it's freaking huge and weighs a ton.. he carries it to class with all of his books and it pretty much always has to be plugged in xD
    intel integrated graphics from 10 years ago could play guildwars.. guess it's the res
  19. DC74
    DC74 Doh!
    4 Jan 2011
    Had to laugh when the article said it was tested in diablo III, that game's been in development so long that had i grown a beard when they announced they were making a 3rd installment, i'd have been able to rival `ZZ Top' by now. Yes the game is newly released, but having tested it for 2 months prior to release, its hardly ground breaking, looks more of an upto date version of the D2 engine with multiplayer added as a main feature and thats about it.
  20. rovit44
    rovit44 What's a Dremel?
    6 Oct 2011
    It was said above >Is anyone using Virtu MVP with the HD4000 and a discreet card? I've not been able to get any non corrupt results from it. < I read (cant find again) that Virtu MVP would best be used with a discrete card similar to the on-chip gpu, which would appear to be HD6450. Would this set up be happy or is there a better card to add to a z77 mobo and use Virtu, or should Virtu be ignored and a wholely better card be used?
Tags: Add Tags
