Intel just got owned?
Discussion in 'Hardware' started by Highland3r, 23 Jun 2006.
  1. Highland3r
    Highland3r Minimodder
    25 Jul 2003
  2. atanum141
    22 Jul 2004
    So other than games what other programs will this have benifits?
    But AMD still has a problem with issues of using DDR2 with high latancies where Intel and the "Core" dont.
  3. Mister_Tad
    27 Dec 2002
    Seems a bit ambiguous...
    So if you're running multiple single threaded apps which does it do? What about a single threaded app and a multi-threaded app at the same time? Does it pick and choose depening on what youre working on at that point in time? Certainly sounds like it isnt ideal for multi-tasking. If it switches over to single-threaded mode when you're running a single threaded app does that mean that background tasks suffer?
    IIRC intel have been talking about a "reverse-HT" for a good long time, I wouldn't be surprised if they unveil something similar that is hiding inside the Core2 architecture (just as they did with HT, which had been hiding inside the Northwoods for years, just hard-disabled)
  4. Tim S
    Tim S OG
    8 Nov 2001
  5. Tim S
    Tim S OG
    8 Nov 2001
    we'll have to see when it comes out... I'm skeptical about things until I find out exactly how something works.
  6. atanum141
    22 Jul 2004
  7. Tim S
    Tim S OG
    8 Nov 2001
    That was the case on 939 too - lower latencies helped improve gaming performance a little. In GPU limited scenarios, latency doesn't make a fat lot of difference.
  8. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    i think its also on the 939 pin chip aswell. that article said its a driver update aswell, its as if its been there all along and just needs activating.
  9. atanum141
    22 Jul 2004
    christ...........its never easy to pick who to use. Well if your saying that then you've just turned my head upside down! first it was AMD then Intel....and now maybe AMD again.
    why cant it ever be simple.
  10. specofdust
    specofdust Banned
    26 Feb 2005
    I'm inclined to think that if works Intel did indeed just get owned. Nice to know theres going to be some competition, and that AMD aren't just going to fall of the map for 7 months.
  11. Mister_Tad
    27 Dec 2002
    Does anyone else think the term "reverse hyperthreading" needs to go?
    It sounds like a 3 year old thought of it tbh :rolleyes:
  12. Matkubicki
    Matkubicki What's a Dremel?
    18 Jan 2005
    An article on overclockers.com made this seem a little less exciting than the Inquirer.
    I think the main point is that as this requires a driver update it should be fairly easy for Intel to do the same thing. If reverse hyper threading really makes a difference Intel will just copy it within a few months (especially since they've already talked about it) and then AMD's advantage will be gone again.
  13. specofdust
    specofdust Banned
    26 Feb 2005
    It's not just a driver update by the sounds of things. It's the ability built into the whole architechture, all the driver will do will enable it. Don't be so sure about Intel copying it either, that might require an entirely new chipset or even socket. If this turns out to be any good Intel got sucker punched.
  14. ch424
    ch424 Design Warrior
    26 May 2004
    Surely that's what happens already with multiple FPUs and ALUs?
    ch424
  15. Matkubicki
    18 Jan 2005
    As mister_tad said it sounds like Intel have been aware of the idea for a while and if it is going to be any good i would put money on them having it in Core 2 already just turned off.
    Oh and one last point the Inquirer article describes a "lowly 3800+" beating an E6300. Not so impressive considering that the E6300 is ~£50 more than the E6300 is listed on overclockers.co.uk
  16. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    oh thats just perfect... At the best of times i am undecisive over what to buy, with my pc even more so... I thought that the intel over amd decision was going to be easy..... damn changeable market! Its like they never heared of standards!
  17. Tim S
    Tim S OG
    8 Nov 2001
    the inq has always been about 'sensationalism'. ;)
  18. Guest-16
    Guest-16 Guest
    Pinch of salt, as ever.
  19. MR BUNGLE
    MR BUNGLE Shoddymodder
    19 May 2003
    ... Still waiting for any kind of confirmation on this of course...
    But if true, it's nice to know AMD havent been sitting on their behinds doing nothing since K8 (apart from AM2)
    should be fun. :naughty:
  20. ch424
    26 May 2004
    Another thought: Crossfire regularly gives just 30% extra for a second card - and that's on graphics, which is relatively easy to split up. If there's a driver dissembling programs to see how to multithread them, surely that's gonna slow it down even more. Can we expect to see even 30% performance gains?
    ch424
