News Intel launches 72-core Knights Landing Xeon Phi
Discussion in 'Article Discussion' started by Gareth Halfacree, 17 Nov 2015.
  1. Gareth Halfacree
    4 Dec 2007
  2. thom804
    thom804 Minimodder
    22 Oct 2009
    Obligatory 'But can it run Crysis?'
  3. Gareth Halfacree
    4 Dec 2007
    This time around: yes, yes it can. I mean, not *well*, given it's an Atom-style low-power core and Crysis ain't going to scale to 72 of 'em, but it'll *run* if paired with a suitable graphics card.
  4. exceededgoku
    exceededgoku What's a Dremel?
    19 Oct 2006
    Perfect hypervisor CPU??
  5. ----jimbo----
    ----jimbo---- What's a Dremel?
    15 Jul 2009
    I'd love to have seen how it did perform as a GPU. I'm sure it had issues, but Intel decided more on the move to integrated rather that discreet that killed it off.
  6. Guest-16
    Guest-16 Guest
    Terrible. 72 CPU cores doing GPU work - even the most basic GPU has 100s of shaders now. Intel has no interest in the driver commitment and low(er) ASPs the discrete graphics market has.
  7. ScottMichaud
    ScottMichaud What's a Dremel?
    18 Nov 2015
    This reply is a little late because it took a few days for my account to be activated.
    But yeah, that's not really true. A GPU shader is not equivalent to a CPU core, because GPU vendors play games with their architecture to do more work with less die complexity. Since they know graphics tasks are typically vector-based (RGBA, XYZW, UV, and so forth) and neighbouring tasks are often very similar (two neighbouring pixels on the screen are probably running the same instructions, just on slightly offset data) they can design a circuit that accepts multiple pieces of work with less logic than if they were crunched individually.
    Knights Landing does the same.
    This "72 core" count is built upon 512-bit registers. This means that, if you have sixteen 32-bit values that always follow the same set of instructions, you can pack them all together. GPUs do the same, NVIDIA packs 32 values into a "warp", and AMD packs 64 values into a "wavefront" (these values can change but it never has yet).
    72 * 16 = 1152.
    Beyond that, each of the 72 cores can support four simultaneous threads. In fact, each of the 72 cores have two, 512-bit vector units. Depending on how you count, this means that Knights Landing (minus any disabled cores) has 1152, 2304, or 4608 shaders. 2304 is probably the most honest value, though.
