News Intel-Micron doubles flash capacities
Discussion in 'Article Discussion' started by CardJoe, 19 Mar 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    Come one price drops! That SSD is nearly within reach!
  3. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    As long as they can supply enough to meet demand. Any lack of supply will push prices up.
  4. shanky887614
    shanky887614 What's a Dremel?
    13 May 2009
    i will buy an ssd when the size is aceptable with a good price untill you can get a 1tb ssd for £100 im not going to buy one (1 tb mechanical hdd nly costs £58 and in custom pc mag, there was a 2tb one for £99
  5. B3CK
    B3CK Minimodder
    14 Jun 2004
    I would be happy with the high performance SSD's at 30Gb or larger, as long as the 30 started at aprox $100 US.
    But if they can drive down the cost of the older drives, I do see this as good development progress.
  6. do_it_anyway
    do_it_anyway Minimodder
    24 Apr 2009
    I think that will be a long way away.
    I will adopt at 256GB for around £200. That way its the same price as a decent graphics card, and has enough space for OS and Games.
  7. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    I'd probably have to wait till it drops to like, 12nm in order to afford one... >.>
  8. GW42
    GW42 What's a Dremel?
    26 Nov 2009
    Really? They obviously don't read tech sites then - http://www.anandtech.com/storage/showdoc.aspx?i=3731 - announced 2 months ago :)
    (EDIT - ok 1 1/2 months ago. & apologies if I have missed a blindingly obvious difference between the 2 stories...)
  9. maximus09
    maximus09 Forever n00b
    8 Jun 2009
    I wouldn't mind buying 128GB for £150, but £300 is stupid. I can afford to buy one now but no way will I spend that much! I think the whole SSD thing is a conspiracy at the moment and companies are artefically inflating the prices buy not producing cheaper NANDs and very few so that the first few years they will earn lots of money without manufactuing lots.
  10. Autti
    Autti What's a Dremel?
    29 Oct 2009
    Screw nand, i want a 25nm CPU!
  11. Bazz
    Bazz Multimodder
    7 Oct 2009
    Exactly, £200 for 256 seems a fair trade between price per gig/performance.
    Crucial started with their M225 series, offering good performance for a reasonable cost, only for the nand manufacturers to raise the pricing of nand chips, meaning Crucial raising their prices. Their 128GB was originally £200, which 6 months ago was good, only to see it hit £300+ in todays market :(
    Also, 1TB SSD?? you can get them, but wanting them for £100, not on your nelly, well not until SSD's stop mechancial drives from being manufactured.
  12. adidan
    25 Mar 2009
    Nope, spot on mate.
    This was officially announced some time ago now, 25nm, larger capacity production Q2, available around Q4.
    Why so late off the mark BT?
  13. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    thing is with vista and win 7 superfetch.. the stuff you use a lot is cached- really for boot times and who cares about that =] I dunno maybe I'm too cynical anymore but if the prices don't compare to drives out (that last)- not going to jump in.. same with the quad, I still don't see anything where I need to upgrade- esp with things moving to the gpu.. it's like raid, don't really care much about it either.. just more things to go wrong and anything like a database you'd want on a harddrive anyway
    when the prices come down some I'll jump into a 256.. but until then really no benefit.. you'd probably put your games on a harddrive also to save writes to the ssd- I guess maybe to impress someone with boot times and shut down woopee =] least acronis lets you select drives into one backup if you want- so that's covered least..
    I'd get one if it wasn't 30 gb for 90 bucks right now on newegg (probably all you need for the os partition) reading about them and firmware updates cause complete data loss? disable system restore, indexing ect.. waiting till all this gets solved and prices aren't so high
  14. Gareth Halfacree
    4 Dec 2007
    Mea culpa - it's only just come to my attention. I must have missed the original announcement, otherwise I'd have written about it then.
  15. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    25nm! Holy-****. There isn't many numbers left..lol. What's it gonna be in a few years, Micro Nanometer?
  16. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    No, no conspiracy.....a traditional hard drive costs around the same price to manufacture regardless of the storage size; where as an SSD is dependent on the price of the individual chips that go up to make the drive. So for example a 128gb drive might contain 64 chips that cost the manufacture $5 each to buy in depending on NAND prices at the time.
  17. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Well, there are some components that will cost the same regardless. Such as the plastic housing, the controller, the PCB that everything is stuck on, the SATA and power ports, etc. The price can never go below these no matter how small you go, just like mechanical drives all must have a housing and read/write heads etc, with varying amounts of platters or varying capacities on those platters changing costs between total capacities.
    The "conspiracy" with SSDs is the NAND manufacturers charging far more for their product than it costs to produce.
  18. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    I just bought a 34nm 80 X25 :/
  19. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    yes yes price drops and higher capacities. ^_^
  20. Anfield
    Anfield Multimodder
    15 Jan 2010
    And thanks to the manufacturers working together we even get legalized price fixing...
    When even a crippled 40GB SSD that is called "value" costs almost 100£ something is definitely wrong.
    Lucky me for jumping on the ssd bandwagon early enough to avoid the price increases, but upgrading to a bigger one is currently just not possible.
Tags: Add Tags
