Intel Nic issue
Discussion in 'Tech Support' started by Buzzons, 30 Jul 2006.
  1. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    I have an onboard Intel pro 1000 CT and a PCI intel pro 1000 MT both with the latest drivers etc, When I go into the Configeration for either of the cards and make a change (viewing is ok) and click ok it becomes unresponsive, and just stops working.. the connection doesnt drop, just the Config page hangs. I have to reboot to get it working, and the setting has not taken. Anyone got any ideas?
  2. riluve
    riluve What's a Dremel?
    29 Jun 2004
    you could try to uninstall the drivers for one or the other and do everything you can to disable the card without drivers. It could be their drivers are clashing somehow.
  3. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    See thats what I thought, so i removed the non-onboard one and removed its drivers and it stil happens for the onboard CT, so Im lost for ideas.
  4. riluve
    29 Jun 2004
    Sounds like a bad driver then. I would check with the MoBo manufacturer for a new version and work with them to get it fixed.
  5. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    im runnin the latest driver from the asus website for the board (its an asus pc dl deluxe) also tried the Intel CT drivers for the card -- both dont work any more.. they used to though.
