PSU Intel NUC - 65w Vs 90w PSU
Discussion in 'Hardware' started by monkeyville, 1 Oct 2020.
  1. monkeyville
    monkeyville Evilish Monkey ++;
    3 Aug 2003
    I have acquired a used intel NUC8i5BEH which is supposedly a 90W model.
    The PSU supplied from the eBay seller is a 19V 3.42A PSU which is 65W. Supposedly this was supplied when it was purchased...
    The NUC runs and powers up without any apparent issues but I'm unsure if this is an issue I should ask them to rectify?
    Does running this at a lower wattage cause issues that I need to address? Am I being too cautious?
  2. yuusou
    yuusou Well-Known Member
    5 Nov 2006
  3. RedFlames
    23 Apr 2009
    This seems to imply that it's supposed to come with a 90W power brick
    It *should* be ok with a 65W brick but you might run into problems if you hammer it or have a load of stuff connected [though that's true of all of those kinda systems]
  4. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    I guess the amperage would be low, but if you're not beating the hell out of it I don't imagine it'd be a huge problem..
    90w power brick is likely to be something like 4.7 amps, assuming it's also 19v.
  5. monkeyville
    3 Aug 2003
    Yeah it's hard to know at what level the underpowered PSU might be an issue.
  6. monkeyville
    3 Aug 2003
