Scratch Build – In Progress [Intel NUC Competition]-Black Heart by Soul-i-Doll
Discussion in 'Project Logs' started by Soul-i-Doll, 11 Mar 2015.
  1. Soul-i-Doll
    Soul-i-Doll What's a Dremel?
    9 Mar 2015
    Hello everyone!
    I'm Denis.
    I got package at last. Here it is.:clap:
    My Preciousss)
    So it's time to work.:dremel:
    My project is called Black Heart.
    The form of it remind origami, I hope) I'm going to use 3D printing to implement it.
    That's all at this point.
    Good luck to all the participants.:thumb:
  2. griso
    griso What's a Dremel?
    9 Sep 2014
    I like that design.
  3. Hzza
    Hzza Minimodder
    15 Apr 2013
    Stealth NUC, look forward to this :D
  4. Waynio
    Waynio Relaxing
    20 Aug 2009
    Keenly watching. :)
  5. Impeccable Logic
    Impeccable Logic What's a Dremel?
    9 Mar 2015
    Cool design.
  6. Combatus
    16 Feb 2009
    Excellent - glad you got the parcel Denis!
  7. Soul-i-Doll
    9 Mar 2015
    Hello everyone.
    I finished my project at last.
    I apologize for the small number of photos because I often forgot to postpone the tools and take a camera.
    Probably I need a personal photographer)
    And now in order about how I did it.
    After I received a printed body I realized that it must be modify by file a little.
    I didn't use acetone because it notably smoothes corners.
    Therefore I armed with putty and sandpaper and handle it.
    So I mutilated it but it was smooth and sharp corners.
    Apply the primer and then painted.
    Then attach the stand for the board using glue.
    It's time to create a key.
    From a piece of sheet aluminium cut the workpiece.
    With needle files gave the desired shape.
    File off and polish.
    Magnet glued to the end of the key.
    Assemble extenders for the front panel of the board.
    And install them on their places in the case.
    Set reed switch instead of the start button.
    It remains only to put everything together and the project is ready.
    That's all.
