Scratch Build – In Progress [Intel NUC Competition]-MiniNUC by Pavel (finished)
Discussion in 'Project Logs' started by Pavel, 10 Mar 2015.
  1. Pavel
    Pavel What's a Dremel?
    9 Mar 2015
    My name is Pavel. I want to introduce you to my project miniNUC. Because of the wide range of applications platform NUC projected case should easily fit into any interior (room, office, children's room or a media console in your living room), so I chose the classic materials (wood and aluminum) and a very compact size. The use of solid wood shell will reduce the number of parts to a minimum and system integration will not take long.
    3d sketch
    NUC Kit
    Materials and tools
  2. Combatus
    16 Feb 2009
    Yay! Welcome to bit-tech and good luck with the build :)
  3. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    The more wooden cases the better :thumb: Best of luck dude :)
  4. Waynio
    Waynio Relaxing
    20 Aug 2009
    Keenly watching. :)
  5. GiGo
    GiGo was once a nerd.....
    12 May 2002
    Like the concept, will be watching this :)
  6. Pavel
    9 Mar 2015
    part 1 - wooden body
    I used the electric jigsaw and router. with glue and clamps I glued the body.
    using electric router and template cut a hole for ventilation
  7. Pavel
    9 Mar 2015
    part 2 - aluminum chassis
    I used a T-shaped profile to create a chassis for motherboard
  8. Pavel
    9 Mar 2015
    part 3 - front and back panels
    Carved panels of the same shape as the the case. I attached the aluminum plate to the body and processed them cutter.
    Pasted paper template and cut out holes for the connectors of the motherboard.
  9. Pavel
    9 Mar 2015
    part 4 - painting
    I used acrylic paint for the body.
  10. Pavel
    9 Mar 2015
    part 5 - final
    Soldered connectors and struck the inscription on the front panel.
    Later add the final image.
  11. Bygone
    Bygone Minimodder
    15 Apr 2015
    This look really cool, love the look of Wood on a pc build, good job.
  12. Ocelot
    Ocelot Minimodder
    4 Apr 2013
    Well done man. The way you made the front panel is really neat. Great results too. The case reminds me of of high end HIFI equipment.
  13. storm-83
    storm-83 Minimodder
    7 Nov 2014
    don't know how i missed this build
    have to agree 100%
    this looks really good!!!
    quick question though;
    how did you put the "icons / writing" on the front of the case?
  14. Pavel
    9 Mar 2015
    I used a heat toner transfer method of making PCBs. such as in the video
  15. Cheapskate
    13 May 2007
    Well done. :D I love how you used old mobo risers to fix the plates.
