Hardware Intel NUC DC53427RKE / HYE Review
Discussion in 'Article Discussion' started by Meanmotion, 4 Oct 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. jrs77
    jrs77 Modder
    17 Feb 2006
    The new Haswell-equipped NUCs should hit the shelves within the next weeks.
    http://www.intel.com/content/www/us/en/nuc/nuc-board-d54250wyb.html
    As you can see at a glimpse, the called for SATA-port is now implemented and there'll be an HD5000-IGP aswell. For the HTPC-usability there's also an infrared sensor thrown into the mix.
  3. Combatus
    16 Feb 2009
    Good good! We'll see if Intel can send us one ASAP!
  4. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Too bad that frequencies are down to 1.3 / 2.6 (instead of 1.8/2.8) in order to fit the HD5000. It's 500MHz less without turbo (-28%). Guess it'll rapidely turbo.
    Back on the current i5 NUC, I'd be currious to know if it can run the latest Terraria (1.2) @1080p. Anyone know ?
  5. jrs77
    jrs77 Modder
    17 Feb 2006
    Think of a teeny tiny HTPC-box with a 1TB 2.5" HDD for mediafiles and an integrated infrared sensor for the remote. In addition to the mSATA for a fast responsive OS, the WiFi and four USB 3.0 ports.
    Or think of a teeny tiny workstation in a 11cm cube, which gives enough room to slap a 92mm cooler onto the board, so it's no problem if the system runs on turbo-mode the whole time :)
  6. richms
    richms What's a Dremel?
    24 Mar 2003
    Is it just the single USB3 port?
  7. Combatus
    16 Feb 2009
    Yes just the single one - no header. Cases like the Akasa Newton V have a male to female cable for it.
  8. CopperX
    CopperX IT Support BOFH @ a Uni.
    4 May 2010
    These (or more appropriately the Haswell one) are pretty good for what we use them for at my Uni. We've got around 5 60" plasma displays that are on wheels so we can move them around and these are pretty good stuck on the back of them so they always go out with a PC.
    Makes it far easier to use that faffing around hooking up a laptop to it.
  9. exceededgoku
    exceededgoku What's a Dremel?
    19 Oct 2006
    I look at these as a router box, I wouldn't use one for media of any kind. Need something with more beef!
  10. ArthurB
    ArthurB What's a Dremel?
    17 Jul 2011
    A Core i5 is fast enough to play 1080p videos? How much beef do you need? A whole cow's worth?
  11. Yaka
    Yaka Modder
    26 Jun 2005
    whens the haskwell version due out?
  12. jrs77
    jrs77 Modder
    17 Feb 2006
    Sometime within the next two month, if there's no delay.
Tags: Add Tags
