Hardware Intel NUC Kit NUC5i3RYK (Core i3-5010U) Review
Discussion in 'Article Discussion' started by Combatus, 11 Feb 2015.
  1. Combatus
    16 Feb 2009
  2. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Conclusion:
    ''We've already heard rumours that a Core i7 version is likely to appear at some point but even this Core i7 model offers enough grunt for most tasks''
    Repeat of i7 I believe.
  3. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Nice little bit of kit, but I'd like to see an i5 version tested.
    Oh, and the last paragraph:
    Presumably that second "i7" should be "i3" :)
  4. Combatus
    16 Feb 2009
    Sorted, thanks!
  5. Combatus
    16 Feb 2009
    I was surprised it didn't have one too tbh - it is a pre-production sample and only one model so maybe there will be SKUs that include one.
  6. Shirty
    18 Apr 1982
    This is roughly as quick as a Sandy Bridge Pentium rig, with much quicker graphics. Plus it uses a fraction of the power. I like progress :)
    Looking forward to seeing the i7 version, might need to put a PO in to replace my Wolfdale-based work rig...
  7. samkiller42
    25 Apr 2006
    Rumours? If you did some homework, and looked on Intel, you'll see the i7 version listed as "NUC5i7RYH" with the note: "The first ever Intel NUC with Intel® Core™ i7 processor is coming in Q2’15! Product details coming soon."
    Sam
  8. Sim0n
    Sim0n rm -rf /
    14 Dec 2001
    Read and read ?
  9. Yukionno
    Yukionno What's a Dremel?
    9 Mar 2010
    Page 2, 5th image, the one on left above the Bios screen grab.
    It shows header with 5 pins above the front panel connector which has the text label "SATA PWR" under it...
    I'm assuming it would be a custom cable not supplied with that model/kit type as there's no space in the case to put a sata drive.
    Bungletron likes this.
  10. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    I have to say that I really love the form factor of these NUCs. I have serious hankerings for one to live behind my telly in the living room, but to be honest I can't help fell that they are a little on the expensive side.
  11. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    Not enough connectivity for a HTPC though... nowhere to put a dual tuner (the mini PCI-E dual tuner Avermedia A373 is rarer than hens' teeth) and only one SATA, so you can't add Blu-Ray DVD alongside your harddisk. Seriously, nobody seems to make HTPC friendly hardware when it's such an obvious market.
  12. RedFlames
    23 Apr 2009
    But didn't you get the memo... netflix [etc.] is the future...
    EDIT: FWIW I agree with you, but i can't see them changing their minds...
  13. John_T
    John_T Minimodder
    3 Aug 2009
    Good grief you've got good eyesight!
  14. Nexxo
    23 Oct 2001
    Would be cool. Bet it will only be a single tuner though, thus rendering it useless.
    I mean, I've got a Sony Brava, right? It has everything: HD DVB tuner, on-screen TV guide, internet browser and video streaming software, the ability to timer-record and pause live TV simply by plugging in a USB harddisk. Basically it is a media centre. Except that it only has one tuner, so you cannot record one thing while watching something else. For the want of £20,-- worth of electronics a £1200,-- top-end TV is reduced to just being a monitor for a whole separate media centre of an additional several hundreds of pounds. :rolleyes:
  15. RedFlames
    23 Apr 2009
    Why include £20 worth of widget in the TV when they can sell you that very same widget [bundled with a load of crap you don't need/want] a substantial mark-up separately...
  16. Shirty
    18 Apr 1982
    I use triple tuners all the time. Everything I ever want to watch is always on at the same time.
  17. nimbu
    nimbu Multimodder
    28 Nov 2002
    Typo spotted
  18. blacko
    blacko What's a Dremel?
    30 Jul 2012
    all i want is something like this with a mGPU in it. Is that to much to ask?
  19. Bungletron
    Bungletron Minimodder
    25 May 2010
    He's got a point, just behind the blue external usb ports.
    A recent upgrade I did made all minuscule vesa bracket type pcs suddenly look very attractive to me as tv tuner equipped HTPCs, that is their use in conjunction with DVBLink running on a server or NAS. By installing all your tuners in a server then the DVBLink server software will be able to share them as a single multituner device to all with any computer on the network by installing a small piece of client software. My Netgear ReadyNAS now has three tuners installed and shared so I could probably migrate my HTPC to miniscule and get rid of the dedicated quad tuner there.
  20. Nikumba
    Nikumba Minimodder
    29 Aug 2001
    Might have to get me one of these, but as a number of people will be looking at this version for a HTPC some benchmarks of media playback in things like Plex, XBMC would be welcomed
Tags: Add Tags
