News Intel reveals eight-core laptop CPU with 5GHz boost and overclocking
Discussion in 'Article Discussion' started by bit-tech, 23 Apr 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    So what's the catch, 5Ghz in a 8 core unlocked mobile CPU seems to good to be true, there must be a catch.
  3. RedFlames
    23 Apr 2009
    Probably either going to be silly money or run hotter than the sun. Possibly both.
    Mr_Mistoffelees likes this.
  4. Spraduke
    Spraduke Lurker
    23 Sep 2009
    Or run at 5 Ghz for 1.2 nanoseconds before thermal throttling to essentially the same speed as previous gen.
  5. Mr_Mistoffelees
    Mr_Mistoffelees The Bit-Tech Cat.
    26 Aug 2014
    Or, the cooling system will sound like a cordless Dyson on full power.
    Silly money can probably be taken as read.
  6. Anfield
    Anfield Multimodder
    15 Jan 2010
    It is possible to have an 8 core 5ghz Turbo 45W TDP premium price notebook part, we "just" have to stretch the definition of some words to their limit:
    Turbo: Single core, no requirement to be capable of maintaining that clock long term.
    Available: As long as a handful chips pass the extra tight binning process and escape the Fab then it counts as available.
    TDP: Avg under an Intel defined workload that may not be representative of the actual average, much less peak values.
    Premium price: With zero competition in the notebook market they can charge whatever they want.
    Notebook: Includes 5 kilogram 17" bricks and disregards things like user discomfort from loud fans.
  7. Corky42
    30 Oct 2012
    The image in the article doesn't show what the little number 1 caveat is, would be handy to see the footnotes.
  8. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    'Turbo Boost' operates like it always has done: clock up when thermal headroom available, clock back down when unavailable. For normal laptop workloads (idling, then do stuff right now, then idle) that works great. If you're using a laptop as a desktop replacement and want to push renders or whatever other sustained loads, then you already know you're going to need a laptop with a beefier cooling system.
    No need to feign ignorance of how every CPU and SoC (including mobile devices) have operated for he last decade.
  9. Corky42
    30 Oct 2012
    It's not feigning ignorance, non tech literate people wouldn't have a clue about the caveats you've just described, they'd see a laptop with a label that says 5Ghz and automatically assume that's better and while it maybe slightly better it's rather misleading to say 5Ghz if that's only available 5-10% of the time or not at all.
    It's a bit like the classic "up to" advertising for broadband or MPG figures that nobody in the real world could ever achieve.
  10. Anfield
    Anfield Multimodder
    15 Jan 2010
    With 504563 models out in the wild no one (beyond a handful of nerds in places like bit-tech) is going to see through the Intel mobile CPU lineup any way;)
Tags: Add Tags
