News Intel reveals more Sandy Bridge details at IDF
Discussion in 'Article Discussion' started by Claave, 14 Sep 2010.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. Hustler
    Hustler Minimodder
    8 Aug 2005
    What is the point of these intergrated Gfx cores on the CPU?.......what useful purpose do they serve?...
    What market are Intel going after?. If they are giving you inbuilt Gfx, how are they taking market share away from Nvidia/AMD?.....
    Those who need extra Gfx grunt, will still buy a dedicated Gfx card anyway.......will the inbuilt Gfx cores be able to be used as an additional benefit to a dedicated card, or are they bypassed once you add a dedicated Gfx card?....
  3. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    Sounds interesting. I doubt I'll be upgrading for a long time yet, but the 2x 8 lane PCI-E sounds good. Hopefully this will mean fewer boards with the second slot limited to 4 lanes.
    As for the TDP, hopefully at the least Intel will release 'normal TDP's and a 'max TDP'. Don't know if that's likely but it would be better than having a single figure that isn't right half the time.
  4. BlackMage23
    BlackMage23 RPG Loving Freak
    4 Aug 2006
    Sounds like they will be for business PC's.
  5. Mraedis
    Mraedis What's a Dremel?
    5 Sep 2009
    Motherboards would not require GPU's anymore, the cooling of the CPU/GPU would be concentrated and the shared cache etc would mean less need of RAM.
    Of course, you'd use this type of core for desktops that aren't meant for gaming or otherwise video-heavy tasks, such as simple office management and regular browsing.
  6. TSR2
    TSR2 What's a Dremel?
    19 Aug 2009
    If all 4 cores can overclock simultaneously, surely that's basically SpeedStep on a per-core basis? After all, if everything's good, its simultaneously awful.
  7. frontline
    frontline Punish Your Machine
    24 Jun 2007
    Saw a few perfomance figures for the integrated GPU recently and it looked quite impressive when compared to something like a 5450 dedicated card. Certainly a lot better than Intel's previous integrated efforts and probably makes the entry level cards costing around £35-£45 redundant.
  8. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    Maybe online gaming in work is back on the menu boys and girls!
  9. dangerman1337
    dangerman1337 Minimodder
    2 Sep 2010
    I wonder if intel are going to annouce details of the die shirnk and its tick tock after 22nm?
  10. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    overall it seems to me that sandy bridge is just a few touch-ups to nehalem. its nice to hear their integrated video is improved but i still think amd's and nvidia's are going to be better. on top of that, you can use the integrated video of an amd or nvidia chipset and use a descrete video card to get more processing power for free. with intel, you get a worse integrated video that doesn't have a descrete card to merge with, but, you at least can do sli or crossfire.
    overall i find a cpu with built-in video a bad idea for desktops. you end up paying more for something you're probably not going to use. its a great idea for mobile devices or mini itx boards, but for a full-blown desktop its just dumb. i'm not too sure i like the idea of intel using the l3 cache for video either. sure, it'll make a great performance difference for video but the cache is going to have to be large, and the whole purpose of cache is to have a SMALL amount of memory that is quick to access.
Tags: Add Tags
