Hardware Intel Skylake: Intel Z170 Chipset and Core i7-6700K Review
Discussion in 'Article Discussion' started by Dogbert666, 5 Aug 2015.
  1. Hustler
    Hustler Minimodder
    8 Aug 2005
    Zen will only be about as fast as Sandybridge in terms of IPC (according to their own 40% claim) but you'll likely be able to buy a 6 or 8 core Zen for the price of an Intel Quad Core.
  2. Harlequin
    Harlequin Modder
    4 Jun 2004
    its not much faster than the haswell iGPU (anand has results)
  3. Combatus
    16 Feb 2009
    Crysis was actually terrible for showing a difference between high-end Intel CPUs. We ditched it for our X99 testing for that reason - even with two R9 290's there was very little difference - less than BF4.
  4. Combatus
    16 Feb 2009
    I wouldn't go as far as saying it's flawed, as it can have an impact, especially once you introduce dual GPUs like we do with X99 testing. but it's very game-dependant and you're right that most are GPU limited anyway. There are other ways that CPUs are used in games, though, admittedly, but these are pretty tricky to gauge performance-wise.
  5. theshadow2001
    3 May 2012
  6. Combatus
    16 Feb 2009
    OcUK was kind enough to loan us an i5 as we only got an i7 sample from Intel so only fair we list them for it, but yes it can be had for £10-15 cheaper elsewhere ;)
    As we'll continue to 'use' those things in future reviews, we're talking generally here about past, present and future testing not just this review, where we 'used' these tests in the past :) Thanks for the other bits - all sorted now I think!
  7. play_boy_2000
    play_boy_2000 It was funny when I was 12
    25 Mar 2004
    Bummer, I was really hoping for better. Maybe once some M.2 PCIe 3.0 SSDs start hitting the shops, I may be tempted to upgrade.
  8. Thaifood
    Thaifood Minimodder
    24 Apr 2009
    for my single card and 1080p, i am still loving my i5 sandy bridge!!
  9. Deders
    Deders Modder
    14 Nov 2010
    This video shows up the difference between an i5 and i7 devils canyon, i'm sure there would be a bigger difference if vsync was disabled but as you can see the i5 dips below 60fps more often than the i7, despite being overclocked.
    The grass in this level is particularly CPU hungry, it maxes out all cores. it's also a great example of full CPU/GPU power draw, I've not seen any game draw this much power. One of my friend's PSU's blew out during this level.
  10. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    The idea that a game blew someone's PSU is hysterical. :D
  11. theshadow2001
    3 May 2012
    Indeed. So much fail and so much awesome all in the one incident
  12. EurozoneEconomy
    EurozoneEconomy What's a Dremel?
    14 Mar 2015
    Surprised at the score of 85 from Bit-Tech. In every way (IPC, overrall performance gain, gaming performance, temps, voltage/frequency, power draw) this is the worst advancement from tick to tock (or even from gen to gen) from Intel in living memory. Likely the smallest advancement ever as we consider how Moore's Law has slowed to such a crawl only in recent years. In fact, looking at Skylake's gaming performance, it's now not a crawl forward but a creep backwards in performance.
  13. Deders
    Deders Modder
    14 Nov 2010
    I had tried to enlighten him on the way of the PSU and all that Bit-Tech/CustomPC had taught me but he was sure it would be fine as it had been for other games. A lesson hard learned.
  14. SchizoFrog
    5 May 2009
    @Deders, if you honestly believe that a game was responsible then I suggest you go back and re-read everything you have ever read about PSU's...
  15. Deders
    Deders Modder
    14 Nov 2010
    Am very tired now so can't remember everything but from what I do remember, he'd bought it because it said 80+ on it, don't think it was even bronze or on the 80+ website. The 12v rails didn't add up to anywhere near its rated wattage and it didn't have much protection on it.
  16. Jasio
    Jasio Made in Canada
    27 Jun 2008
    This is worth a read: http://www.anandtech.com/show/9483/intel-skylake-review-6700k-6600k-ddr4-ddr3-ipc-6th-generation/14
    The R7 240 used in the comparison is slower than the 750Ti... but not a bad benchmark against a $70 (~£45) GPU.
    Apart from the rather steep pricing on Skylake... the motherboards aren't cheap either =/
  17. TheMadDutchDude
    23 Aug 2013
    The pricing is the same as Haswell, it's not steep but rather normal. It's Intel, it's new, it's going to sell, so milk the cash cow! :D
  18. Harlequin
    Harlequin Modder
    4 Jun 2004
    the gtx 750ti is twice as fast as the 240.....
  19. TheMadDutchDude
    23 Aug 2013
    That it is. However, you'd go down the Broadwell route if you needed the iGPU performance. Skylake is aimed at enthusiasts and gamers with dedicated cards whom are NOT looking to use the iGPU.
  20. maverik-sg1
    maverik-sg1 Minimodder
    18 Aug 2010
    I still love my 2500K, but over time I realised that I do things that would benefit from HT more often than I once thought. If I upgrade now, the 6700K would be my choice, but I'm going to put it off a little longer to let DDR4 and the boards mature a bit (read as drop in price).
    But it finally looks like a good enough reason to upgrade and a good excuse to get the HT enabled CPU this time.
Tags: Add Tags
