Intel V8 Powah (PICS!)
Discussion in 'Hardware' started by Guest-16, 5 May 2007.
  1. Guest-16
    Guest-16 Guest
    8 Cores, Two CPUs, 4GB of FBDIMMs and a PCI-Express x16 port. ;)
    Oh and uh.. one hard-on :hehe: :lol: :blush:
  2. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    Questions ;)
    what motherboard is that?(and what form factor)?
    What 53xx xeons are in use?
    Oh and where did you pick up the FBRAM is there anywhere cheep?
    Only asking cos I am looking to upgrade my 4core xeon setup to that ^_^
  3. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Toasty.
  4. identikit
    identikit Minimodder
    5 Jun 2004
    Looks like a Intel S5000XVN to me.
  5. Guest-16
    Guest-16 Guest
    You, Sir, are indeed correct in this observation. It's got some 3GHz 1333s in it but I can't remember the model number off hand.
  6. Jipa
    5 Feb 2004
    Can I have two of them? :] True hardwarepr0n.
  7. Cabe
    Cabe What's a Dremel?
    14 May 2002
    worshippers need another PCIe slot.
  8. identikit
    5 Jun 2004
    Are they stock or overclocked at 3Ghz? Because I don't remember any quad-core xeons at 3Ghz. The highest clocked 1333 xeon is X5355 at 2.66.
  9. identikit
    5 Jun 2004
    Forgot to mention its SSI EEB form factor. Its very similar to the current SSI CEB, in that they have the same mounting as ATX boards, but they are slightly larger, only by about an inch or so though.
  10. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Make ones of these with another 1 or two PCI-E slots and without the expensive FB-DIMM RAM and it'll sell like crazy.
  11. Guest-16
    Guest-16 Guest
    Maybe I shouldn't have said anything then :blush:
    If these posts are deleted later, you know why :worried:
    The problem is you need Fully Buffering otherwise your northbridge has to act as a distribution hub between 8 cores all wanting and waiting for memory access, so FB's provide a respectively better performance until Intel integrates each chip with its own memory controller.
    It does have two x8 slots as well, although I'm not sure if we're allowed to "mod them" in order to accept an x16 card :dremel:
  12. identikit
    5 Jun 2004
    Ha admit it! You "can't remember the model number off hand" because it doesn't exist yet!
    I just noticed the space for another x16 slot next to the one that is there. Hmmmm.
  13. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    pshaw, only 4gb? i get to play with a 12CPU 24GB RAM machine at uni :lol:
  14. Mary Jo
    Mary Jo oh lolz
    13 Oct 2004
  15. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    Will that kind of mobo fit into a lian li PC71 then? (probs big enough?)
    Why would you need more PCI-e slots , it isnt like it is aimed at gamers... shame you will have to use one of the PCI-x slots for a soundcard though.
  16. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    well I will never have a need for it but it's still pretty cool, I have always wanted a dual socket mobo
    to bad it isn't LGA775
  17. fatty
    fatty Minimodder
    12 Jul 2004
    And I hear the new 1333 fsb chips are fine if you don't overclock ;) especialy the quad core chips
    Oh and there is always the mod you can use on the old qauds to make them 1333 fsb
  18. identikit
    5 Jun 2004
    Found a pic of my old Inline-4
    I'm actually really considering another 4 socket computer, this time a AMD workstation*. Only way to get 8 AMD cores atm. 4x4 is misleading...
    I think the computer industry needs more car analogies.
    * I've finally lost the plot completely.
  19. ComputerKing
    8 Sep 2006
    OMG 8 Cores !! this thing rocks ... :rock:
    Nice find , thanks
  20. Tim S
    Tim S OG
    8 Nov 2001
    it's my new CPU benchmark development system ;)
