Motherboards Intel Xeon MOBO
Discussion in 'Hardware' started by antec900, 12 May 2010.
  1. antec900
    antec900 Minimodder
    11 May 2009
    i have never taken an intrest in server motherboards befor so i thought ide take a look. Can someone please tell me what type of expansion slots are on this motherboard and what they are for?
    Sorry for my ignorence and ide appreciate any help
  2. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Ok. Dell server board, appears to be socket 604, from a DELL DD444 system
    Main Features
    # Features : Dual Socket MPGA 604 for Intel P4 Xeon CPUs (NOT Included)
    Backplate Tray IS included
    1 VRM slot (the one above the cpus)
    6 USB and 1 Firewire port in back
    2 USB ports in front (using Precision 670 case)
    Two SATA Connections
    Integrated AC'97 audio
    Integrated 10/100 Lan
    Two UDMA 33, ATA-66/100 IDE connectors
    One Floppy Connector
    1 - 16x PCI-E Slots
    1 - 4x PCI-E Slot
    1 PCI Slot
    1 Expanded PCI Slots (64bit?)
    6 DDR DIMM slots
    1 - 68-pin onboard ultra-320 SCSI controller (and connector)
    2 Serial/1 Parallel Port
    PS2 Mouse and Keyboard Ports
    Compatible part numbers: MG022, X0392, U7565, XC837
    A very nice board! shame about the proprietary layout and design
  3. antec900
    antec900 Minimodder
    11 May 2009
    Thanks just the answer i needed...
    im actualy quite surprised at the spec of this motherboard
    cheers
  4. confusis
    5 Jan 2006
    Yeah must be a workstation board rather than a server board. I have an AMD 940 board with similar spec. gogo server/ws hardware!
  5. confusis
    5 Jan 2006
  6. antec900
    antec900 Minimodder
    11 May 2009
    wow now thats ugly
    do you think i could make a reasonably powerful workstation out of this MOBO
  7. antec900
    antec900 Minimodder
    11 May 2009
    1 more thing..
    whta psu would i need with this type of motherboard or is it just a standard workstation psu
  8. confusis
    5 Jan 2006
    Could be powerful, depends what socket 604 cpus it supports - could be anything from netburst to nehalem!
    psu? hmm looks like it needs a 20 and 24pin. will research!
    may be easier to find the psu from the original unit
  9. confusis
    5 Jan 2006
  10. antec900
    antec900 Minimodder
    11 May 2009
    hmmm
    the second psu looked compatible with the mobo and a normal case
    are xeon 604 motherboards compatible with all intel xeon 604 processors or just certain types?
  11. confusis
    5 Jan 2006
    certain types. google time again
  12. confusis
    5 Jan 2006
  13. antec900
    antec900 Minimodder
    11 May 2009
    Thanks man youve just about answered all of my questions appart from one lol
    Ok whta Is the VRM slot and what is its purpose... if i need to install one can you give me en example of the type i would need to look for...
    As i said im new to theses mobos so you will have to bare with me lol
    thanks
  14. confusis
    5 Jan 2006
  15. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    HINT: If you haven't already, give this guy some +rep ;)
  16. confusis
    5 Jan 2006
    I'm too modest to ask :)
    antec900 likes this.
  17. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    The expanded pci slot is most likely PCIx, it's a 64bit extension of PCI with the clock rate bumped up to between 66 and 533MHz though most likely 133MHz. It's what servers used before PCIe became ubiquitous and you can often find pretty decent kit at very reasonable prices for it now that companies are upgrading to PCIe ( I picked up a 16port Adaptec hardware SATA RAID card for about £80).
    Moriquendi
