News Intel's Core i7-3970X Extreme Edition hits the UK
Discussion in 'Article Discussion' started by Gareth Halfacree, 15 Nov 2012.
  1. Gareth Halfacree
    4 Dec 2007
  2. Bobman
    Bobman What's a Dremel?
    10 Apr 2012
    I'll take two!!
  3. TheDodoKiller
    TheDodoKiller Minimodder
    23 Oct 2011
    hmm... yeah! Good value!
  4. Anfield
    Anfield Multimodder
    15 Jan 2010
    If it was an 8 core Ivy Bridge I'd be prepared to pay the asking price, but as it is? no thank you.
  5. andrew8200m
    andrew8200m Multimodder
    4 May 2009
    Been in store for over 2 weeks in the odd place... Thats late Oct/early Nov.
  6. Omnituens
    Omnituens What's a Dremel?
    5 Apr 2006
    I'm still pissed that adopters of 1366 got totally shafted :(
  7. andrew8200m
    4 May 2009
    How???
  8. rollo
    rollo Modder
    16 May 2008
    1366 has a 6 core cpu that is not alot slower than this just a bit more power usage is its main fault. And its still a hell of alot faster in the tasks its designed for than any ivy or sandy cpu outside of the 6series.
  9. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    1366 hex-core chips are still very much in the "high performance" bracket and could easily hold their own against the latest quads in hyperthreaded performance.
    I'm surprised that Intel aren't ditching the hex-core stuff as they already have something better?
  10. law99
    law99 Custom User Title
    24 Sep 2009
    Can you imagine the heat? You could probably mount a wok to it and start cooking your Thai green.
  11. azazel1024
    azazel1024 What's a Dremel?
    3 Jun 2010
    Well, TDP wise, Ivy runs about 20 odd % less than Sandy. Actual power consumption tends to be a little lower than. I think the 3570k NOT overclocked runs about 25% less power then the 2500k also not overclocked in most workloads. That is with slightly higher clocks on the 3570k.
    So I'd assume a straight hex core IV-E processor running at, say, 3.7Ghz and maybe 4.2Ghz max TC probably would run around 120w TDP. Going from 6 to 8 cores would up your TDP to 160w.
    Ramp back the clock rate slightly, and you are probably at the same 150w TDP with 8 cores for an Ivy Bridge E model running around 3.4-3.5Ghz.
    You could similarly get a 6 core chip with around 3.3Ghz clock speeds probably in the 110w TDP range.
    Really, I am looking forward to Broadwell. I know Intel is pushing TDPs and general use power consumption lower and lower, which is a good thing, but I really hope with Broadwell, well finally see "mainstream" hexacore processors for desktops at least and octocore for higher end stuff.
    Give me quad core ULV processors and hexacore enthusiast desktops (and maybe even a hexacore laptop 45-47w extreme part or something) with octocore high end parts and I'll be a happy, happy boy.
  12. Guest-44432
    Guest-44432 Guest
  13. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Not sure why that would be. They got the very best at the time and are still very capable now. The socket was left due to intels tick tock strategy, introducing new sockets every couple of years to make way for new features.
  14. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
    Completely pointless waste of money
  15. Anfield
    Anfield Multimodder
    15 Jan 2010
    3970X TDP = 150W
    3770K TDP = 77W
    2x 3770k TDP = 154W
    154W minus the parts that don't need to be doubled up (graphics for example) = lower TDP than 3970X.
    And the heat isn't really an issue, Ivy Bridge runs hot for two reasons, one: the tiny contact area between the die and the ihs, two: the crappy tim used by Intel.
    The contact area would obviously scale pretty much linear with an increased number of cores and the crappy tim, well I'm sure Intel can find something better than what they use in the 3770K, so an eight core Ivy Bridge is far from impossible, there are other reasons why they won't release one.
  16. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    gutted it's still 6/12 cores/threads. Wish I'd never sold my 970....
  17. fluxtatic
    fluxtatic What's a Dremel?
    25 Aug 2010
    I don't see Intel coming out with mainstream hex- or octa-core mainstream processors for quite a while - why should they bother? Multi-core processors have been around for what, 6-7 years now, and software still hasn't caught up. It's still not terribly common to see mainstream software where more than 2 cores makes a hell of a lot of difference. Toss in another 2 cores for OS processes, etc, and you've still got more processor than you need.
    Workstations running professional software are different, obviously, but that's not what Intel's Extreme series are for, really, are they? They're pure e-peen.
  18. Pookeyhead
    30 Jan 2004
    I don't think so!!
    Interestingly though (for me any way)... would a 3960X work in a Stormville board? @Bindi... Asus gonna do a top end Stormville board?
    YEHBABY likes this.
  19. Griffter
    Griffter What's a Dremel?
    1 Jun 2012
    i'll have what his having...
  20. Shirty
    18 Apr 1982
    Still very happy with my 2500k thanks.
