Hardware Intel's Solar-Powered CPU
Discussion in 'Article Discussion' started by arcticstoat, 21 Sep 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    Such a low power draw and Solar powered is surely a good thing to carry on the developement process. Can't really think of any downside here at all.
  3. rinseout
    rinseout What's a Dremel?
    8 Mar 2011
    I don't tend to use my desktop outdoors very much, nor for that matter in a sunlit room.
    But if I did, this would be good for me.
  4. slothy89
    slothy89 MicroModder
    17 Feb 2011
    Presumably the same could be achieved from mains power? Using an appropriate PSU of course.
    My guess is the reason for the solar power is it was quicker to hook up than make a custom PSU AND custom wiring
  5. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    Thanks for clearing up exactly what was being demonstrated. It's somewhat less impressive when you realise it's ONLY the CPU that's being powered by the solar panel. It's still quite a cool concept, and it really does start to show that performance can be achieved by parallel processing, as opposed to high MHZ.....
    Now, if only multi-threading was blindly available - it was controlled or at least able to be controlled at a hardware level, rather than having to write code units to specifically take advantage of multicore technology, then I'd be seriously impressed...
  6. benji2412
    benji2412 <insert message here>
    25 Apr 2009
    Probably worth asking if you've any details on the solar cell, although I'm guessing intel won't say anything about that. I'd be more impressed with this chip if that wasn't a tandem cell and perhaps an amorphous silicon cell.
  7. Claave
    Claave You Rebel scum
    29 Nov 2008
    Yep!
  8. tonyd223
    tonyd223 king of nothing
    12 Nov 2009
    Instant computing - never turn the machine off, but don't pay a penalty on standby power...
  9. Paradigm Shifter
    10 May 2006
    Someone needs to go back and do basic Maths again! ;)
    10mW = 1/100th of a Watt.
    Given that in your own words, "Ultra-low voltage CPUs currently consume 15W or more" that would be 1500 times as much power - you're out by a factor of 10. Or, 15W = 15000mW. 15000/10 = 1500.
    Claave likes this.
  10. Alexg
    Alexg What's a Dremel?
    2 Jan 2010
    The reason for using solar is that it gives a good demo - its more interesting visually than using a special power supply. Solar powered PCs are not the future (for obvious reasons) but low power ones are.
  11. Claave
    29 Nov 2008
    :blush: changed, thanks.
    I don't think that's in doubt - the demo was a clear and interesting way to show how low-power Claremont is - the question is to what purpose? Is Claremont a single-core low-power system based around Socket 7, a demonstration of a new kind of SpeedStep based on Near-Threshold Voltage, an illustration that many-core (32+) CPUs are viable within modern TDPs or all of these, or something else?
  12. lp rob1
    lp rob1 Modder
    14 Jun 2010
    The main problem with NTV is that the transistors change state too slowly, and other transistor mis-interpret the signal. Currently we simply increase the voltage so it gets there quicker, but if Intel develops faster switching transistors then NTV could become mainstream quickly.
  13. mclean007
    mclean007 Officious Bystander
    22 May 2003
    It's a tech demo. If Intel can overcome the problems with near threshold voltage (and this demo shows they can) then it could be rolled out to CPUs throughout the range - everything from Atom to the top of the line Xeons could benefit from tech that allows the power to drop by a factor of 1,000 when idling. It could be licensed to the GPU fabs as well - who wouldn't want a GPU capable of next generation gaming performance but which draws milliwatts when in Windows?
  14. Claave
    29 Nov 2008
    ^but if it's just a demo, why the codename? Does that not suggest this is a product?
  15. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    This would be great if it were not for the lack of sunshine in the UK most of the times during winter etc unless I am missing the point of what solar power is, which currently I think is sunlight on to a cell, which charges a battery or powers a device and when said sunlight goes then the battery stop's charging or the device stop's working.
    It would be good to see a cpu and gpu that would consume less than 100w of juice as then I might not spend as much on electric each year :(
  16. JerryW
    JerryW Relative Newbie...
    10 Mar 2010
    Bit of a dog's breakfast, this article, wasn't it? Having failed to ask the right questions (or at least, get the right answers) you are reduced to speculation about what the code name might mean etc. You admit to being confused, and not without reason! It is an interesting area but with no flesh on the bones means nothing really
  17. CampGareth
    CampGareth What's a Dremel?
    15 May 2009
    Just the other day I was thinking to myself "I want to leave my laptop on so I don't miss instant messages and so on but it's got very little airflow and I'm worried about it. I wish there were a way to drop the multiplier to 1 or less, drop vcore etc. so it's still on and running but with practically no heat output"
    Is there anything stopping us doing this with current systems?
  18. brave758
    brave758 Minimodder
    16 Apr 2009
    Lol we all know that CEO's love to geive their pet projects names makes them feel more "special"
  19. Farfalho
    Farfalho Minimodder
    27 Nov 2009
    I can't believe I'm going to say this but Intel might be on something here, something really great and might take the lead in every market and data servers will be the ones benefiting the most of it. That kind of SpeedStep is rather more pleasing on the eye and tech specs than the ridiculous of today.
    Let's see if it doesn't turn out another Larabee =X
  20. ZseLotH
    ZseLotH What's a Dremel?
    15 May 2008
    This is great if ever made to commercial produt. Should come handy where it's hard to get electricity.
    But requirements for this to be very useful is (I think) that it should run win7 with solar panel(during a cloudy day) no bigger than palm of a human hand, which indeed would be a great feat indeed.
Tags: Add Tags
